Smart Technologies Interactive Smartboard M680
Quicklinx: 9HW9WS00 Mfr#: SBM680
Your SMART Board M600 series interactive whiteboard is durable and reliable. It features a rugged, hardened interactive surface, two damage-resistant pens and SMART's proprietary DViT (Digital Vision Touch) technology.
  • DViT technology
    Four digital cameras, one in each of the interactive whiteboard's corners, track the position of your finger or the pen as it moves across the interactive surface.
  • Multitouch gestures
    Your interactive whiteboard supports multitouch gestures. You can use two fingers to resize an object on a page, to rotate an object, to zoom in and out and more.
  • Dual touch and dual write
    Your interactive whiteboard supports dual touch. Two users can use their fingers to simultaneously perform mouse functions or write on the interactive whiteboard.
  • Durable surface
    The interactive surface is scratch-resistant, dent-resistant and optimized for projection.
SMART Board Interactive Whiteboard M680 - interactive whiteboard - USB - white, light grey
Interactive whiteboard
Wired - USB
White, light grey
166 cm x 15.3 cm x 131.2 cm
Movement Detection Technology
Digital vision touch
Steel frame
1 x USB cable - external - 5 m
Apple MacOS, Microsoft Windows
166 cm
15.3 cm
131.2 cm
White, light grey
Input Device
Wired
USB
Active Area
156.5 cm x 117.5 cm
Steel frame
1 x USB - 4 pin USB Type A
Pen tray, styluses (2 pcs)
CSA, RoHS, WEEE, REACH, ERP
Software Included
SMART Notebook
Limited warranty - whiteboard - 2 years
5 °C
35 °C
0 - 80% (non-condensing)
