Smart Technologies Board® 8070i interactive display
Quicklinx: 960YWS00 Mfr#: SBID8070i-G4-SMP
The SMART Board 807CH-G4 interactive flat panel features SMART'S proprietary DViT (Digital Vision Touch) technology on an LCD screen with e-LED backlight which enables you to select, write and erase on the interactive surface. By touching the surface, you can do everything on the interactive flat panel that you can do at your computer, and you can use an array of gestures within applications.
You can also write or draw over any application in digital ink using pens or your finger, and then erase the digital ink using the supplied eraser or your palm. Two users can write or draw at the same time. The interactive flat panel has two presence detection sensors on its frame that can detect people up to 16' (5 m) away. When the sensors detect people in the room, the interactive flat panel turns on. When the sensors no longer detect people in the room, the interactive flat panel turns off.
SMART Board Interactive Flat Panel 8070i-G4-SMP - LED monitor - Full HD (1080p) - 70"
LED-backlit LCD monitor - 70" - touchscreen
Touch-screen
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.807 mm
Brightness
250 cd/m²
Contrast Ratio
4000:1
Input Connectors
2xHDMI, DVI-D, 2xVGA, DisplayPort, S-Video, composite video, component video
Speakers
Integrated
Voltage
171 cm x 15.8 cm x 110.5 cm
93 kg
UL, VCCI, C-Tick, NOM, CB, IC, PSB, FCC, RoHS, WEEE, REACH, KC, ERP, China EIP, BIS
Display Type
Diagonal Size
70"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.807 mm
Brightness
250 cd/m²
Contrast Ratio
4000:1
Vertical Refresh Rate
48 - 62 Hz
Horizontal Refresh Rate
54 - 69.75 kHz
Backlight Technology
LED backlight
Digital Vision Touch (DViT)
93 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
10 Watt
Input
Touch-screen - touchscreen
2 x audio line-out (mini-jack) , USB 3.0 (Type A) , USB 2.0 (Type A) , USB 2.0 (Type B) , Serial input , Serial output , DisplayPort , 2 x HDMI , DVI-D , 2 x VGA , VGA output , Component video , Composite video , S-video , Audio line-in (mini-jack) , Audio line-in (RCA x 2) , Audio line-out (RCA x 2)
Mechanical
VESA Mounting Interface
800 x 400 mm
Remote control, spare pen tips, GoWire auto-launch cable, CAT 5 USB extender, pens and eraser, I/O extension module
1 x USB cable - 1.3 m , 1 x USB extension cable - 5 m , 1 x HDMI cable - 6.3 m
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
310 Watt
Power Consumption Stand by
40 Watt
Power Consumption Sleep
0.5 Watt
Included Software
SMART Meeting Pro PE
5 °C
35 °C
5 - 80% (non-condensing)
