This all-in-one SMART Board brings devices, lesson content and software together without any unnecessary cables. It includes advanced features to help teachers and students collaborate with ease
The SMART Board® 7075 interactive display with iQ is the hub of your classroom. iQ technology is used to connect devices, lesson content and pedagogically relevant software to create a unified educational experience. It’s hassle-free as there’s no need for wires, cables or manual software and firmware updates. The 75" 4K ultra-high-definition LED display provides optimal image clarity and wide viewing angles for your whole class. The Pen ID™ feature allows you to assign different appearances to the four pens and write or draw over any application using digital ink. Object Awareness™ allows you to perform mouse functions with your finger, write in digital ink with the pen, and erase with your palm or eraser—all without switching tools or modes.
- SMART Board 7075 75" LED display
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 75"
- Commercial Use
- Yes - interactive communication
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- HDMI
- HDMI Ports Qty
- 3 ports
- Connectivity
- LAN, Bluetooth
- PC Interface
- VGA (HD-15), DisplayPort
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:09
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- Voltage
- AC 120/230 V (50/60 Hz)
- 162 Watt
- 172.9 cm x 12.4 cm x 109.5 cm
- 75 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3 years warranty
