Peerless-AV SmartMount Universal Tilt Wall Mount for 60" to 95" Flat Panel Displays
Quicklinx: 7MVFWS00 Mfr#: ST680P
Type: Mounting kit
£184.30 ex VAT
£221.16 inc VAT
Ideally suited for XXX large LCD and plasma screens, the SmartMount ST680P tilting wall mount allows you to mount even the very largest flat panel screens quickly and easily.
  • Effortless adjustment
    The tilt feature of the Peerless SmartMount Universal Tilt Wall Mount allows for easy viewing angle adjustments, ensuring an optimal viewing experience from any position.
  • Robust design
    Designed to support flat panels ranging from 60" to 98", this mounting kit can hold up to 159 kg, making it a reliable choice for securing large screens.
  • Comprehensive mounting solution
    With included fasteners, tilt bracket, and wall plate, the Peerless SmartMount Universal Tilt Wall Mount provides a comprehensive solution for installing your flat panel display, ensuring a hassle-free setup.
Peerless SmartMount Universal Tilt Wall Mount ST680P mounting kit - for flat panel - black
Mounting kit
Mounting Components
Wall plate, tilt bracket, fasteners
116 cm x 7.6 cm x 76.8 cm
Adjustments
Tilt
6.9 kg
Recommended Use
Flat panel
Recommended Display Size
60"-98"
Max Mounting Pattern Size
1061 x 650 mm
Max Load Weight
159 kg
5-year warranty
116 cm
7.6 cm
76.8 cm
6.9 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
1061 x 650 mm
60"-98"
Adjustments
Tilt
Max Load Weight
159 kg
Sorted-For-You
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
