Smart Technologies 7075 75" 4K UHD LED Large Intetractive Display
Quicklinx: D2GRWS00 Mfr#: SBID-7275
This all-in-one SMART Board brings devices, lesson content and software together without any unnecessary cables. It includes advanced features to help teachers and students collaborate with ease
The SMART Board® 7075 interactive display with iQ is the hub of your classroom. iQ technology is used to connect devices, lesson content and pedagogically relevant software to create a unified educational experience. It’s hassle-free as there’s no need for wires, cables or manual software and firmware updates. The 75" 4K ultra-high-definition LED display provides optimal image clarity and wide viewing angles for your whole class. The Pen ID™ feature allows you to assign different appearances to the four pens and write or draw over any application using digital ink. Object Awareness™ allows you to perform mouse functions with your finger, write in digital ink with the pen, and erase with your palm or eraser—all without switching tools or modes.
SMART Board 7075 75" LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
75"
Commercial Use
Yes - interactive communication
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
HDMI
HDMI Ports Qty
3 ports
LAN, Bluetooth
PC Interface
VGA (HD-15), DisplayPort
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:09
TV Tuner
No tuner
Speaker System
2 speakers
USB
Voltage
162 Watt
172.9 cm x 12.4 cm x 109.5 cm
75 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
