The SMART Board® 6065-V2 interactive flat panel with iQ is the hub of your classroom. iQ technology connects devices, lesson content and pedagogically relevant software to create a cohesive educational experience. PC-free embedded computing provides one-touch access to a diverse suite of SMART applications Notebook lessons, amp workspaces, lab gamification activities and whiteboard—and collaborative tools, such as wireless screen sharing and a web browser. There’s no need for wires, cables or manual software and firmware updates. The 65" 4K ultra-high-definition LED display provides optimal image clarity and wide viewing angles. With the Pen ID™ feature, you can assign different appearances to the two pens and write or draw over any application in digital ink. Object Awareness™ allows you to perform mouse functions with your finger, write in digital ink with the pen, and erase with your palm or eraser—all without switching tools or modes. You can use a variety of gestures in applications, and two users can write or draw at the same time.
The high-definition display features low-friction coated glass that lets fingers glide smoothly over the surface, creating a natural touch experience. The SMART Board 4065 interactive flat panel virtually eliminates glare and provides an optimal view from any angle in the classroom. It delivers an unparalleled viewing and writing experience, and offers the best value for classrooms. With eight simultaneous touch points for Windows, multiple students can use gestures, like zoom, rotate and flip, at the same time.
- SMART Board 6265-V2 interactive flat panel with iQ 65" Class (64.5" viewable) LED-backlit LCD display - 4K - for interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 65"
- Diagonal Size
- 64.5"
- Commercial Use
- Yes - interactive
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DisplayPort
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- Speaker System
- 2 speakers
- USB
- Included Accessories
- 2 touch pens, SMART Notebook software, iQ appliance
- Voltage
- AC 120/230 V (50/60 Hz)
- 110 Watt
- Power Consumption Stand by
- 2.2 Watt
- 150.8 cm x 12 cm x 97.8 cm
- 60.9 kg
- 3-year warranty
- Product Type
- 110 Watt
- Diagonal Class
- 65"
- Diagonal Size
- 64.5"
- Commercial Use
- Yes - interactive
- Combined With
- Touchscreen
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DisplayPort
- 150.8 cm
- 12 cm
- 97.8 cm
- 60.9 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 1200:1
- Brightness
- 338 cd/m²
- Viewing Angle
- 178 degrees
- Touchpoints Qty
- 8
- Digital Vision Touch technology
Stands & Mounts
- Flat Panel Mount Interface
- 300 x 400 mm
Media Player
- USB Port
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- 2 x HDMI input - side , 3 x USB 2.0 - side , Audio line-out - side , DisplayPort - side , Serial - side , USB 2.0 - bottom
- Cables Included
- USB cable
- UL, CCC, IC, FCC, RoHS, WEEE, PSE Mark, REACH, KC, EAC, RCM, SPRING
- Power Device
- Power supply
- Input Voltage
- 2.2 Watt
- Limited warranty - 3 years
- Width (Shipping)
- 175.8 cm
- Depth (Shipping)
- 30.3 cm
- Height (Shipping)
- 126.1 cm
- Weight (Shipping)
- 82.1 kg
- 5 °C
- 35 °C
- 5 - 80% (non-condensing)
