The AirLink LS300 gateway has a small footprint for easy installation and a rugged, military spec design that enables it to withstand extreme temperature changes, humidity, shock, and vibration. Certified for hazardous environments (Class I, Div 2), the LS300 is ideal for industrial deployments. The LS300 comes standard with Ethernet, serial, digital I/O, and USB interfaces, as well as GPS.
- Sierra Wireless AirLink LS300 - gateway
- Gateway
- Form Factor
- External
- Data Link Protocol
- Ethernet, USB, Fast Ethernet, RS-232
- Capacity
- VPN tunnels: 5
- Mobile Broadband Access
- Mobile Communication Protocol
- GSM, GPRS, EDGE, HSPA+
- Power
- DC 7 - 28 V
- 9 cm x 7.6 cm x 2.5 cm
- 190 g
- 3-year warranty
- Gateway
- Built-in Devices
- GPS
- 9 cm
- 7.6 cm
- 2.5 cm
- 190 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- TCP/IP, UDP/IP, IPSec, PPPoE, SMTP, DHCP, DNS
- Routing Protocol
- GRE
- Remote Management Protocol
- SNMP, Telnet, SSH
- Capacity
- VPN tunnels: 5
- DMZ port, NAT support, VLAN support, MAC address filtering, IP address filtering, SNTP support, Virtual Route Redundancy Protocol (VRRP) support, port forwarding
- Encryption Algorithm
- IKE, SSL
Communications
- 1 x 100Base-TX - RJ-45 , 1 x RS-232 - DB-9 , 1 x USB 2.0 , 2 x aerial - SMA
- IC, FCC, RoHS, PTCRB, MIL-STD-810, UL Class I Division 2
- Voltage Required
- DC 7 - 28 V
- Limited warranty - 3 years
- -30 °C
- 70 °C
- 0 - 90%
