The NETGEAR LTE Modem LB2120 gives you a simple, fail-safe connectivity solution for your devices or services, avoiding disruptions in broadband when your fixed wire line goes down. Simply connect your existing wire line broadband connection to this modem to provide an automatic 4G LTE or 3G broadband backup connection.
- NETGEAR LB2120 - wireless cellular modem - 4G LTE
- Wireless cellular modem - Gigabit Ethernet
- Form Factor
- External
- Localisation
- United Kingdom
- Max Transfer Rate
- 150 Mbps
- Cellular Protocol
- UMTS, LTE, DC-HSPA+
- Digital Ports Qty
- 2
- System Requirements
- Apple MacOS X 10.6.8 or later, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
- 11.9 cm x 9.91 cm x 3.05 cm
- 181.4 g
- Limited lifetime warranty
- Form Factor
- External
- Localisation
- United Kingdom
Modem
- Bus
- Gigabit Ethernet
- Connectivity Technology
- Wireless, wired
- Max Transfer Rate
- 150 Mbps
- Cellular Protocol
- Digital Ports Qty
- 2
- Antenna
- External detachable and internal
- Remote Management Protocol
- TR-069
- SMS alert
- 2 x 1000Base-T - RJ-45 , 2 x aerial - TS-9
- SIM Card Supported
- Micro-SIM x 1
- Cables Included
- 1 x network cable
- OS Required
- Limited warranty - lifetime
- 11.9 cm
- 9.91 cm
- 3.05 cm
- 181.4 g
