Seagate Exos 10TB X-Class Nearline Enterprise 7200RPM 3.5" 256MB Hard Drive
Quicklinx: D738WS00 Mfr#: ST10000NM0016
Form Factor: 3.5" x 1/3H
Type: Hard drive
Interface Type: SAS
Capacity: 10TB
Spin Speed (rpm): 7200rpm
£281.28 ex VAT
£337.53 inc VAT
Among the industry's best response times for a nearline drive, the Seagate Enterprise Capacity 3.5 HDD (Helium) helps enable some of the fastest data transfers possible. Meet your storage workload requirements with an efficient data center footprint. Innovative technology advancements like PowerBalance, PowerChoice and RAID Rebuild, allow you to have the control to customise your bulk storage requirements for even greater TCO improvements.
  • Built for speed - exactly where it is needed
  • Incredibly high capacity paired with world-class reliability
    When building maximum density server and storage solutions with Seagate's Enterprise Capacity 3.5 HDD (Helium), you can rest easy knowing that your storage infrastructure can scale to meet your growing capacity needs while offering consistent and predictable response rates.
Seagate Exos X10 ST10000NM0016 - hard drive - 10 TB - SATA 6Gb/s
Hard drive - internal - nearline - temperature sensor, T10 Protection Information (T10 PI), Seagate RAID Rebuild, Humidity Sensor, Low Halogen, Super Parity, Hot-Plug Support, Power Balance technology, advanced format 512e, 24x7 availability, Helium technology, Power Choice Idle Power technology, Power Choice Power/Performance technology, Organic Solderability Preservative, Multi-Step Forged Helium Sealed-Drive design, Superior Wide-Weld Hermetically Sealed-Drive enclosure, pressure sensor
10 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Temperature sensor, T10 Protection Information (T10 PI), Seagate RAID Rebuild, Humidity Sensor, Low Halogen, Super Parity, Hot-Plug Support, Power Balance technology, advanced format 512e, 24x7 availability, Helium technology, Power Choice Idle Power technology, Power Choice Power/Performance technology, Organic Solderability Preservative, Multi-Step Forged Helium Sealed-Drive design, Superior Wide-Weld Hermetically Sealed-Drive enclosure, pressure sensor, S.M.A.R.T.
101.85 mm x 147 mm x 26.11 mm
650 g
5-year warranty
10 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
4096
101.85 mm
147 mm
26.11 mm
650 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
254 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
2,500,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
4.5 Watt (idle) , 8 Watt (read) , 6.5 Watt (write)
Limited warranty - 5 years
5 °C
60 °C
5 - 95% (non-condensing)
Shock Tolerance (operating)
70 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
250 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.5 g @ 22-350 Hz
Vibration Tolerance (non-operating)
2.27 g @ 10-500 Hz
Type: Hard drive
Interface Type: SAS
Capacity: 10TB
Brand: Seagate
Price Range Ex VAT: 150 - 300
