BarraCuda leads the industry with the highest capacities for desktops and mobile computers. The uncompromising BarraCuda Pro marries industry-leading storage capacity with 7,200-RPM spin speeds for snappy performance and load times when gaming or performing heavy workloads.
Get the most out of your storage with BarraCuda hard drives. From computers full of photos and memories to gaming PCs that need more room to play, BarraCuda grows with you.
Versatile, fast and dependable
BarraCuda leads the industry with the highest capacities for desktops and mobile computers. The uncompromising BarraCuda Pro marries industry-leading storage capacity with 7,200-RPM spin speeds for snappy performance and load times when gaming or performing heavy workloads. -
Amazing versatility
Get the most out of your storage with BarraCuda hard drives. From computers full of photos and memories to gaming PCs that need more room to play, BarraCuda grows with you. -
3.5-inch Barracuda hard drives deliver
Rock-solid reliability built on over 20 years of BarraCuda innovation. Versatile mix of capacity and price point options to fit any budget. Multi-Tier Caching Technology for excellent hard drive performance. -
All hard drives in the BarraCuda family come equipped with Multi-Tier Caching Technology (MTC). MTC takes your PC to the performance levels, so you can load applications and files faster than ever before. By applying intelligent layers of NAND Flash, DRAM and media cache technologies, BarraCuda delivers improved read and write performance by optimizing data flow.
- Seagate Guardian BarraCuda ST4000LM024 - hard drive - 4 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 4 TB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 128 MB
- Spindle Speed
- 5400 rpm
- QuietStep, Halogen Free, Ramp Load
- 69.85 mm x 100.35 mm x 15 mm
- 190 g
- 2-year warranty
- Capacity
- 4 TB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 128 MB
- Bytes per Sector
- 4096
- 69.85 mm
- 100.35 mm
- 15 mm
- 190 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 140 MBps
- Spindle Speed
- 5400 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- SATA 6 Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 1.9 watt (read) , 2.1 watt (write) , 1.1 watt (idle)
- RoHS
- Limited warranty - 2 years
- 0 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Shock Tolerance (operating)
- 300 g @ 2 ms
- Shock Tolerance (non-operating)
- 650 g @ 1 ms
