Seagate 6TB Ironwolf 3.5" SATA 6GB/s 7200RPM Hard Drive
Quicklinx: DCL9WS00 Mfr#: ST6000VN0033
The Power of Agility for home, SOHO and SMB NAS enclosures. IronWolf is designed for everything NAS. Get used to tough, ready and scalable 24/7 performance that can handle multi-drive environments with a wide range of capacities.
Seagate IronWolf ST6000VN0033 - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal
6 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Halogen Free, NAS compatible, 24x7 availability, Dual-Plane Balance, Error Recovery Control
101.85 mm x 146.99 mm x 26.11 mm
705 g
3-year warranty
6 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.85 mm
146.99 mm
26.11 mm
705 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
198 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Limited warranty - 3 years
5 °C
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
70 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
