Seagate 600GB 10,000RPM 128MB 12Gb/s SAS 2.5" Enterprise HDD
Quicklinx: D5QSWS00 Mfr#: ST600MM0218
The Seagate Enterprise Performance 10K HDD is an ideal 1.2 TB hard drive for mission critical applications. It delivers best-in-class mission critical random performance, highest capacities and the low power that data centers need to meet demanding service level agreements and to keep up with data growth and reduce IT operating costs.
  • Maximize storage investments for the long haul
    Exos 10E2400 offers protection information to help protect against data corruption. RAID recovery is faster and safer.
  • Superior data security features
    With instant secure erase, drive retirement is safe, fast and cost effective.
Seagate Exos 10E2400 ST600MM0218 - hard drive - 600 GB - SAS 12Gb/s
Hard drive - internal
600 GB
Hardware Encryption
Encryption Algorithm
256-bit AES-XTS
2.5" SFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
128 MB
Spindle Speed
10000 rpm
Idle Read After Write (IRAW), PowerChoice, Error Correction Code (ECC), Seagate RAID Rebuild, LED status indicator, Dual Port, upgradable firmware, advanced format 512n, Drive Self Test (DST), S.M.A.R.T.
70.1 mm x 100.45 mm x 15 mm
222 g
5-year warranty
600 GB
Hardware Encryption
256-bit AES-XTS
2.5" SFF
SAS 12Gb/s
Buffer Size
128 MB
Bytes per Sector
512
70.1 mm
100.45 mm
15 mm
222 g
Performance
Drive Transfer Rate
1.2 GBps (external)
Internal Data Rate
215 MBps
Average Latency
2.9 ms
Spindle Speed
10000 rpm
Reliability
MTBF
2,000,000 hours
Recoverable Errors
10 per 10^12
Non-Recoverable Errors
1 per 10^16
Seek Errors
10 per 10^8
Expansion & Connectivity
2 x SAS 12 Gb/s - 29 pin internal SAS (SFF-8482)
Compatible Bay
2.5" SFF
Power Consumption
6.68 Watt (active) , 3.44 Watt (idle)
ICES-003, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI CNS 13438, ISO 7779, KCC KN22, KCC KN24, cUL No.60950-1, China RoHS, AS/NZS CISPR 22, RCM, EMI/EMS Class B, CAN/CSA-CISPR 22-10, FCC Part 15 Class B, ACMA, EN 62368-1, IEC 62368-1
Limited warranty - 5 years
5 °C
55 °C
5 - 95% (non-condensing)
Shock Tolerance (operating)
40 g @ 11 ms
Shock Tolerance (non-operating)
400 g @ 2 ms
Vibration Tolerance (operating)
0.5 g @ 5-500 Hz
Vibration Tolerance (non-operating)
3 g @ 5-500 Hz
Sound Emission
24 dB
