Seagate 12TB BarraCuda Pro SATA 6GB/s 7200RPM Hard Drive
Quicklinx: D9X7WS00 Mfr#: ST12000DM0007
Select:
  • 12TB
Lightning-fast performance and titanic storage give your desktop or creative professional system the edge you need to be your very best.
  • Robust durability
    Engineered to withstand the rigors of daily use, the Seagate Barracuda Pro offers a high non-recoverable error rate of 1 per 10^15 and a substantial load/unload cycle of 300,000, ensuring reliability and data integrity over time.
  • Efficient performance
    With an impressive internal data rate of 250 MBps and a large 12 TB capacity, this hard drive meets the demands of intensive data applications, while features like Native Command Queuing (NCQ) enhance performance efficiency.
  • Eco-friendly design
    The Seagate Barracuda Pro stands out with its Halogen Free construction and PowerChoice technology, which optimizes power consumption during active, idle, standby, and sleep modes, making it an environmentally conscious choice.
  • Advanced connectivity
    Featuring a Serial ATA-600 interface, the hard drive ensures high-speed data transfer rates up to 600 MBps, facilitating quick and seamless access to large files and applications.
  • Data protection
    Bundled with 2 years Seagate Rescue Data Recovery, this hard drive offers an additional layer of data protection, ensuring your valuable data is safeguarded against unforeseen events.
Seagate Barracuda Pro ST12000DM0007 - hard drive - 12 TB - SATA 6Gb/s
Hard drive - internal
12 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Halogen Free, PowerChoice, Hot-Plug Support, Worldwide Name (WWN), advanced format 512e, Perpendicular Recording, S.M.A.R.T.
101.85 mm x 146.99 mm x 26.11 mm
705 g
5-year warranty
Bundled with
12 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
4096
101.85 mm
146.99 mm
26.11 mm
705 g
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
250 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,000,000 hours
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
7.8 Watt (active) , 4.83 Watt (idle) , 0.84 Watt (standby) , 0.8 Watt (sleep)
Software Included
Seagate SeaTools
BSMI, ICES-003, EN55024, EN55022 Class B, RoHS, China RoHS, RCM, ASTM B845, FCC Part 15 J Class B, ACMA, Directive 2014/30/EU, ANSI C63.4-2014, AS/NZS CISPR 32
Limited warranty - 5 years
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
5 - 95% (non-condensing)
Shock Tolerance (operating)
70 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
250 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.5 g @ 22-350 Hz
Vibration Tolerance (non-operating)
2.27 g @ 2-500 Hz
