Sanus VuePoint Full-Motion Mount - 32"-47" TVs
Quicklinx: FW2CWS00 Mfr#: F215c-B2
Type: Mounting kit
Hurry, only 2 left in stock!
£41.66 ex VAT
£49.99 inc VAT
The SANUS VuePoint F215c is a versatile full-motion wall mount solution for most 32" - 47" flat-panel TVs up to 60 lbs. Its full range of movement allows smooth extend, tilt, swivel and roll motions up to 15.4" from the wall without the use of tools. The F215c tilts ±15º with the touch of a finger, making it easy to reduce glare. In-arm cable management channel conceals cables the length of the mount for a seamless appearance.
Sanus VuePoint mounting kit - for flat panel
Mounting kit
Mounting Components
Full motion wall mount
Tilt
30°
Pan
90°
Recommended Use
Flat panel
Recommended Display Size
32"-47"
VESA Mounting Interface
Up to 400 x 400 mm
Max Load Weight
27 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Up to 400 x 400 mm
Cable Management
Integrated cable management
32"-47"
Tilt
30°
Pan
90°
Max Load Weight
27 kg
Resources
The following resources are available for the Sanus VuePoint Full-Motion Mount - 32"-47" TVs
Type: Mounting kit
Brand: Sanus
