The SANUS VuePoint F215c is a versatile full-motion wall mount solution for most 32" - 47" flat-panel TVs up to 60 lbs. Its full range of movement allows smooth extend, tilt, swivel and roll motions up to 15.4" from the wall without the use of tools. The F215c tilts ±15º with the touch of a finger, making it easy to reduce glare. In-arm cable management channel conceals cables the length of the mount for a seamless appearance.
- Sanus VuePoint mounting kit - for flat panel
- Product Type
- Mounting kit
- Mounting Components
- Full motion wall mount
- Tilt
- 30°
- Pan
- 90°
- Recommended Use
- Flat panel
- Recommended Display Size
- 32"-47"
- VESA Mounting Interface
- Up to 400 x 400 mm
- Max Load Weight
- 27 kg
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- Cable Management
- Integrated cable management
- 32"-47"
- Tilt
- 30°
- Pan
- 90°
- Max Load Weight
- 27 kg
