SanDisk Ultra microSDHC /microSDXC UHS-I Memory Cards have everything you need to take better pictures and great quality videos. The cards' Class 10 speed rating makes them ideal for shooting Full HD (1080p) video and high resolution photos, while outstanding transfer speeds (up to 80MB/sec) make light work of saving images and footage for editing and sharing.With capacities that extend all the way up to a world-leading 128GB, there's also room to store thousands of high resolution photographs and hours of Full HD (1080p) video. With the included adapter this card can be used as a full-size SDHC/SDXC card for compatibility with your camera, camcorder, laptop, tablet and other devices that support the SDHC/SDXC standard.
- SanDisk Ultra - flash memory card - 32 GB - microSDHC UHS-I
- Product Type
- Flash memory card
- Form Factor
- microSDHC UHS-I Memory Card
- Storage Capacity
- 32 GB
- Speed Rating
- Class 10
- Included Memory Adapter
- microSDHC to SD adapter
- Microsoft Certification
- Compatible with Windows 7
- 10 years warranty
- Product Type
- Flash memory card
- Storage Capacity
- 32 GB
- Compatibility
- Non-specific
- SD Speed Class
- Class 10
- Read Rate
- Up to 80 MB/s
- Form Factor
- Shockproof, magnetic-proof, waterproof, write protection switch, X-ray-proof, temperature-proof
- Limited warranty - 10 years
- 14.99 mm
- 10.92 mm
- Thickness
- 1.02 mm
- 4.54 g
