Sandisk 16GB Extreme Pro SDHC 280MB/s
Quicklinx: BHBFWS00 Mfr#: SDSDXPB-016G-G46
The SanDisk Extreme PRO SDXC UHS-II 16GB card brings you the high performance that today's professional photographers and videographers need to take outstanding shots with high-speed burst mode and capture cinema-quality 4K and Full HD videos . With faster transfer speeds, it also helps you improve post-production workflow efficiency to give you better all-round results. The world's fastest SDXC card, the 16GB SanDisk Extreme PRO SDXC UHS-II card delivers up to 250MB/s write speed. With that speed, you can take remarkable continuous burst-mode shots with your DSLR to make sure that you capture the one you want. Once you've taken your photos, extreme transfer speeds of up to 280MB/s ensure that your workflow becomes even more efficient. The SanDisk Extreme PRO SDXC UHS-II 16GB card also helps you capture high-quality video: it meets the new U3 video capture specification with a minimum sustained video capture rate of 30MB/s for cinema quality 4K, 3D and Full HD video recording . Best results come when used in conjunction with the SanDisk Extreme PRO SD UHS-II Card Reader/Writer (available separately).
  • The capacity you need to store more
    Devices today are expected to do more and store more. 16GB SanDisk Extreme PRO SDXC UHS-II memory cards give you ample room for both planned and spontaneous high-quality shots and videos.
  • Make more of speed
    SanDisk Extreme PRO SDXC UHS-II 16GB memory cards are the world's fastest SDXC cards, with extreme read speeds of up to 280MB/s and write speeds of 250MB/s so that you benefit from better shot to shot performance. For professional video recording, U3 sustained video capture at 30MB/s delivers cinema-quality 4K, 3D and Full HD .
  • Performance anywhere
    Water proof, temperature-proof, shock-proof and x-ray-proof, SanDisk Extreme PRO SDXC UHS-II 16GB memory cards are designed to be used almost anywhere. They will even pass through airport scanners unharmed.
  • Reassurance with performance
    You can shoot with total peace of mind. SanDisk Extreme PRO SDXC UHS-II 16GB memory cards are backed by a lifetime limited warranty .
  • Add extra efficiency
    Pair SanDisk Extreme PRO SDXC UHS-II 16GB memory cards with the sleek, compact SanDisk Extreme PRO SD UHS-II card reader/writer for an excellent way to increase performance and workflow efficiency. Just 2.25 inches (57.15mm) long, the reader/writer (available separately) supports USB 3.0 interface transfer speeds of up to 500MB/s , allowing you to download high resolution photos and videos onto your desktop or laptop up to 10 times faster than a USB 2.0 interface can support.
SanDisk Extreme Pro - flash memory card - 16 GB - SDHC UHS-II
Flash memory card
SDHC UHS-II Memory Card
Storage Capacity
16 GB
Speed Rating
UHS Class 3 - 1667x/1867x
Software Included
RescuePRO Deluxe (1 year download)
Flash memory card
Storage Capacity
16 GB
Speed Rating
1667x/1867x
Speed Class
UHS Class 3
Read Rate
Up to 280 MB/s
Write Rate
Up to 250 MB/s
Shockproof, waterproof, X-ray-proof
Software Included
-25 °C
85 °C
