Sandberg Adapter PS/2 on USB-port
Quicklinx: 6JYYWS00 Mfr#: 504-27
If you need to connect your PS/2 mouse or keyboard, and only have USB ports on your computer, you can attach the device to this smart adapter and insert it directly into the USB port. However, this only works with COMBI devices, which are designed for USB conversion.
  • Versatile Connectivity
    This adapter connects a keyboard or mouse with a 4-pin USB Type-A male connector to systems requiring a 6-pin mini-DIN female connection.
  • Simple Installation
    The Plug-and-Play feature allows easy setup, eliminating the need for complicated installation procedures or software.
Sandberg keyboard / mouse adapter
Keyboard / mouse adapter
Connector
4 pin USB Type A - male
Connector (Second End)
6 pin mini-DIN (PS/2 style) - female
Connector
