Samsung Xpress C1810W Colour Laser Printer
Quicklinx: 9Y77WS00 Mfr#: SL-C1810W/SEE
Print wirelessly and share effortlessly with the Samsung Xpress C1810W. All it takes is a simple tap of the advanced NFC technology, and the Samsung Mobile Print App allows you to take advantage of the powerful mobile features. Simply tap your mobile device to the Samsung Xpress C1810W to print virtually any content.
Whatever size your team, and however busy you are, you can rely on the C1810W to constantly deliver professional, quality color output. Because anything less isn't good enough. Accelerating your business' productivity begins with your printer. With its 19/19 pages per minute output and a first page out time as low as 16 seconds the C1810W delivers where it counts.
  • Makes your smartphone even smarter
  • Get print on tap
  • Print anywhere with Google Cloud Print
    Effortless mobile printing with impressive compatibility, optimized for any task or occasion. Google Cloud Print works on smartphones, tablet PCs, Google Chromebooks, PCs and other web connected devices.
  • Simple registration to Google Cloud
    Google Cloud Print allows you to connect and print from wherever you are. Just tap your smartphone to the printer and automatically connect it to the cloud - no login necessary.
  • No need to call for service
    Confusing error messages are a thing of the past. Just tap your NFC-enabled smartphone to the printer and you'll be guided through a step by step series of troubleshooting images or videos so you can get to work faster.
  • Enjoy professional color output
  • Make sharp images and text even sharper
    Boost the overall quality and vividness of your output with unique ReCP (Rendering Engine for Clean Pages). It automatically adds dots along the edges of images and characters, meaning everything looks so much sharper and cleaner. What's more, those white gaps between colored areas that are so common with other devices are eliminated. What you and your team are left with is an outstanding color output.
  • Make colors more vibrant
    The advanced Polymerized Toner formulation has smaller and more uniform particles, giving lines extra definition, and color more impact. Its higher wax content not only improves mage gloss, but also enhances print durability by preventing unwanted fading. And as the polymer toner can be applied in a thinner layer with lower fusing temperatures, it reduces the paper curl and energy consumption as well.
  • A higher level of printing performance
  • More power, better productivity
    With the power of two cores the device can process files simultaneously and the 256MB memory ensures large print jobs won't slow it down.
  • USB direct
    Print images and PDFs directly from a USB memory stick, which can be plugged in directly below the operating panel.
  • Cost effective printing
    Stay in control of your expenses. Lower costs per page and a more energy efficient printer means lower costs for you or your business.
  • High yield, low costs
    Higher yield cartridges means more time between changes, saving you time, while low toner costs means less cost for every page. You'll find the Total Cost of Ownership is slashed.
  • Less power, less to pay
    There is more money to be saved by reducing power consumption. The innovative polymerized toner requires a lower fusing temperature, resulting in less energy consumption. With a typical energy consumption (TEC) of only 1.3kWh (less than 1.52kWh with Wi-Fi Direct enabled) this printer saves you on money and reduces energy waste.
  • Eco printing
    One push of the Eco button lets you save on costs. Print multiple pages on one sheet, skip blank pages or print in grayscale. You can edit the defaults at any time to customize how you print and how much you save.
Samsung Xpress C1810W - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
16.62 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 18 ppm - B/W - A4 (210 x 297 mm) , Up to 19 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 18 ppm - colour - A4 (210 x 297 mm) , Up to 19 ppm - colour - ANSI A (Letter) (216 x 279 mm)
Max Resolution (Colour)
9600 x 600 dpi
USB 2.0, Gigabit LAN, Wi-Fi(n)
533 MHz
RAM Installed (Max)
256 MB (512 MB)
Language Simulation
PCL 5C, PostScript 3, PCL 6C, SPL (Samsung Printer Language), PDF 1.7
Media Type
Envelopes, transparencies, labels, plain paper, cards, bond paper, recycled paper, cotton paper, thick paper, thin paper, glossy paper
Total Media Capacity
250 sheets
Media Handling
250-sheet paper cassette, 1-sheet multipurpose tray
Monthly Duty Cycle (max)
40000 pages
Print server
UNIX, Linux, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Apple MacOS X 10.5 - 10.9
42 cm x 42.6 cm x 26.4 cm
Printer Type
Printer
Print Speed
Wireless
9600 x 600 dpi
First Print Out Time B/W
16 sec
First Print Out Time Colour
16 sec
Language Simulation
Media Handling
533 MHz
RAM
RAM Installed (Max)
256 MB / 512 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), 98 x 127 mm
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 220 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Output Trays Capacity
100 sheets
Duty Cycle
40000 pages
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 700 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 700 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 700 pages ISO/IEC 19798
Power supply - internal
380 Watt
Power Consumption Stand by
50 Watt
Environmental Standards
ENERGY STAR
Sound Emission (Idle)
32 dBA
Sound Emission (Operating)
50 dBA
42 cm
42.6 cm
26.4 cm
16.62 kg
