Samsung SP-U300M Mobile Projector
Quicklinx: 6N3NWS00 Mfr#: SPU300MEX/EN
The Samsung SP-U300M provides you with a precision projector that can be taken with you wherever you go. By using a high-performance lamp, Samsung has been able to reduce the size of the projector, giving you a mobile, versatile presentation and entertainment tool.
The Samsung SP-U300M delivers instant access to entertainment through its innovative USB interface. With its built-in multimedia player, you can enjoy a wide variety of video, music, and picture files with no need for an additional PC. Simply plug in, play, and bathe in the beauty of a truly cinematic experience.
With the world's best brightness in the pocket projector category, the Samsung SP-U300M is the most powerful performer in its class. Providing up to 100" of precision projection, its innovative lamp delivers an incredible 300ANSI lumens of brightness and a phenomenal 1100:1 contrast ratio, enabling you to experience rich color, deep detail, and a clear picture in any lighting condition.
With built-in stereo speakers (2 x 1W) and a convenient remote control, the Samsung SP-U300M is an all-in-one home theater solution. Its tilt feature enables you to position the screen with versatility and precision so that you can enjoy exceptional multimedia entertainment in any environment.
The pristine white surface and soft, smooth contours of the Samsung SP-U300M is designed to evoke the essence of modern beauty. With its timeless style and low cost of ownership, it suits every style and budget and subtly accentuates any environment that it is placed in.
  • Portable precision projection
  • Direct multimedia access via USB
  • 100" of exquisite entertainment
  • Home theater you can take anywhere
  • Elegantly affordable, exquisitely styled
Samsung SP-U300M - DLP projector - portable - white gloss
DLP projector
White gloss
Built-in Devices
Stereo speakers
Brightness
300 lumens
Contrast Ratio
1100:1
Resolution
SVGA (800 x 600)
Native Aspect Ratio
4:3
Bulb life cycle
Up to 2000 hour(s) - economic mode
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
75 Watt
17.9 cm x 13.1 cm x 5.4 cm
0.85 kg
3-year warranty
DLP projector
Built-in Devices
Stereo speakers
Enclosure Colour
White gloss
Projector
Brightness
300 lumens
Contrast Ratio
1100:1
Image Size
51 cm - 254 cm
Projection Distance
0.82 m - 4.17 m
Throw Ratio
2.0:1
Digital Zoom Factor
4x
Resolution
SVGA - SVGA (800 x 600) (native) / 1280 x 1024 (resized)
Native Aspect Ratio
4:3
Max Sync Rate (V x H)
85 Hz x 70 kHz
Bulb life cycle
Controls & Adjustments
Trapezoid, colour temperature
OSD Languages
English, German, French, Italian, Portuguese, Swedish, Russian, Spanish, Dutch, Chinese, Korean
Integrated de-interlacer (progressive scan)
Head and Stage
Head Type
23 mm
Lens
Focus Type
Manual
Lens Aperture
F/1.8
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, composite video
Video Modes
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
1 Watt
Speakers
2 x right / left channel
Input Device
External
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input , 1 x USB , 1 x audio line-in - RCA x 2 , 1 x headphones - mini-phone stereo 3.5 mm
Wireless remote control
1 x VGA cable
Security Features
FCC Class A certified, UL, cUL, CCC, RoHS
75 Watt
Power Consumption Operational (Standby)
1 Watt
17.9 cm
13.1 cm
5.4 cm
0.85 kg
Limited warranty - 3 years - carry-in , Limited warranty - lamp - 6 months / 1000 hours
Sound Emission
30 dB
