Product
Samsung SmartThings Multipurpose Sensor (2018)
Quicklinx: DS2QWS00 Mfr#: GP-U999SJVLAEA
Type: Multipurpose sensor
Compatible With: Alexa, Google Assistant, SmartThings
19 in stock
£20.00 ex VAT
£24.00 inc VAT
Express delivery Order within the next 2 hours for delivery on Monday
Know when doors and windows are opened or closed.
  • Know when doors and windows are opened or closed.
  • Receive alerts if windows open unexpectedly.
  • Set connected lights to turn on and off as you open doors, windows, and cupboards.
  • Monitor temperature and vibration.
  • Requires a SmartThings Hub or compatible device with SmartThings Hub functionality. https://www.shop.bt.com/DS2N
Add smartness to your home with a SmartThings Multipurpose Sensor. Receive alerts if windows open unexpectedly, set connected lights to turn on and off as you open doors, and much more. Also monitors temperature and vibration.
SmartThings is the easy way to turn your home into a smart home.
  • Your smart home needs a brain, so get started with SmartThings. It connects wirelessly with a wide range of smart devices and makes them work together.
  • Next, add some smart devices and put your home to work. Choose from a wide range of compatible devices, including lights, cameras, locks, thermostats, sensors, and more.
  • Finally, use the Google Assistant, Amazon Alexa, or the SmartThings app to control your smart home. Teach your house new tricks by telling it what to do when you’re asleep, awake, away, and back home.
In the Box
  • SmartThings Multipurpose Sensor (2 parts).
  • Battery, mounting pads, screws, and bracket.
  • Quick-start guide and health and safety guide.
Requirements
  • Requires the free SmartThings app for Android (6.0 or later) or iOS (10.0 or later).
  • Visit SmartThings.com for specifications, support, and more.
Technical Information
  • Power: 1 x CR-2450 battery.
  • Communication Protocol: Zigbee.
  • Range: 15-40 meters depending on your home’s construction.
  • Operating Temperature: 0 to 40°C.
  • Dimensions: 43.7 x 51.8 x 13.7 mm.
  • Weight: 40.8 grams.
  • Color: White.
  • Warranty: One-year limited warranty.
  • Video capability
    Keep an eye on what matters most while you're away. Receive push notifications to live stream what's going on at home, or record video clips 30 seconds before, and for two minutes after a specified event takes place. Download recorded video clips to your smartphone, which are stored for up to 30 days.
  • Simple set-up
    Includes everything you need to get started. No wiring or installation needed: anyone with broadband Internet connection can easily set up their Hub and connect their devices to start easily monitoring and controlling their home from anywhere with the SmartThings smart phone app.
Samsung SmartThings - multipurpose sensor
Multipurpose sensor
Sensor Type
Door and window
Functions
Light control, open/closure control
Power Source
Internet of Things (IoT) Platform
SmartThings
Wireless - ZigBee 3.0
White
1 year warranty
4.38 cm x 1.37 cm x 5.19 cm
Multipurpose sensor
Sensor Type
Door and window
Functions
Power Source
Wireless - ZigBee
Max Range Indoors
40 m
Android 6.0 (Marshmallow) or later, Apple iOS 11 or later
Platform
SmartThings
Adhesive strips
White
Battery Required
1 x CR2450
Warranty
1 year warranty
4.38 cm
1.37 cm
5.19 cm
39 g
Compatible With: SmartThings
Brand: Samsung
Price Range Ex VAT: 0 - 50
