Samsung SmartCam Full HD PoE Outdoor Camera
Quicklinx: CYKNWS00 Mfr#: SNH-V6430BNH/UK
Simple, Smart, Secure SmartCam outdoor helps you look after 24/7 - 1080p Full HD resolution - Weather-resistant housing (outdoor) - Easy installation with PoE adapter - 130° Ultra-wide angle lens - Night vision to 15m(50ft) - Versatile for indoor, outdoor (optional accessory kit for indoor)
  • 1080p Full HD Streaming Video
  • Outdoor Ready (Weather-Resistant)
  • Motion Zone Select
  • True Day and Night
Box Contains
  • Camera
  • PoE Power adapter with plug
  • LAN cable(10m/33 ft)
  • Screws
  • 3 wall anchors
  • QIG
  • General Public License
Hanwha Techwin SmartCam SNH-V6430BNH - network surveillance camera
Network surveillance camera - fixed - outdoor - weatherproof
Audio
Yes: built-in microphone
7.8 cm x 7.8 cm x 7.11 cm
271 g
White
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Optical Sensor Type
CMOS - 1/3"
Minimum Illumination
0.3 lux - colour , 0 lux - B&W
Focal Length Control
Fixed focal
Focal Length
2.8 mm
IEEE 802.11b, Ethernet 10Base-T, IEEE 802.11g, IEEE 802.11n, IEEE 802.11a, IEEE 802.11ac
1 - network cable - external - 10 m
Voltage
PoE Class 3
Progressive scanning, image flip, image mirror, Wide Dynamic Range (WDR), 2D Noise Reduction Technology, Motion Detection Technology, Lens Distortion Correction, 3D Noise Filtering, High Dynamic Range (HDR), Audio Detection, auto white balance, Motion Zone Select
Environmental Parameters (operating)
-30 °C - 40 °C; 0 - 90% relative humidity
Audio Support
Wired, wireless
7.8 cm
7.8 cm
7.11 cm
271 g
Camera
Colour - Day&Night - fixed - outdoor - weatherproof
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Digital Zoom
10
Infrared LEDs
Infrared Distance
15 m
Digital Video Capture Resolution
1280 x 720, 1920 x 1080, 640 x 360
Image Sensor
CMOS 1/3"
Effective Pixels
1944 x 1092
Lens Construction
Fixed focal
Focal Length
2.8 mm
Network Interface
Network Protocols
DHCP, DNS, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, SSL
Ports
LAN/power - RJ-45
Supported Memory Cards
SDXC Memory Card
PoE adapter
1 x network cable - external - 10 m
White
Power Requirements
PoE Class 3
6.7 Watt
-30 °C
Relative Humidity (operating)
0 - 90%
