Netatmo Smart Sensor
Quicklinx: H4RWWS00 Mfr#: DTG-UK
Be alerted even before a break-in occurs.
  • Take action even before an intruder breaks into your home
    The smart door and window sensors alert you to a problem even before a break-in occurs. Installed on the doors and windows of your choice, they can tell if someone is trying to force entry. They also detect when a door or window is opened suddenly and send an immediate notification to your smartphone. This saves you valuable time in the event of a break-in.
  • See whether doors and windows are open or shut - directly in the app
    You can adjust the settings in your app to keep an eye on your home at all times by configuring smart door and window sensors to send you a smartphone notification if a door or window is kept open too long. Just left home but think you might have left something open? You can check whether doors and windows equipped with a sensor are open or shut directly in the app.
  • Easy to install
    Smart and straightforward - that's the thinking behind Netatmo products. The smart door and window sensors are no exception! Simply stick the one-piece waterproof sensors to any type of door or window.
Netatmo - door and window sensor (pack of 3)
Door and window sensor
Packaged Quantity
3 (specifications are for single item)
Environment
Indoor, outdoor
Sensor Type
Door and window, motion, vibration
Power Source
Wireless
3.04 cm x 1.58 cm x 7.6 cm
Packaged Quantity
Sensor Type
Environment
Indoor, outdoor
Power Source
Wireless
Waterproof
AAA type
Required Qty
2
Adhesive strips
Warranty
FCC
3.04 cm
1.58 cm
7.6 cm
220 g
