Samsung SL-C460FW A4 Colour Wireless Laser 4 in 1 18PPM 1 Tr
Quicklinx: B3FSWS00 Mfr#: SL-C460FW/SEE
Print wirelessly and share effortlessly with the Samsung Multifunction Xpress C460FW. With advanced NFC technology, Wi-Fi direct and powerful compatibility, all it takes is a simple tap.
This printer helps streamline workflow and ensures that your office is working as efficient as possible. The Multifunction Xpress C460FW offers flexibility and lets you work with less barriers. A host of innovative features like ID copy, N-up copy, scan-to-email and the convenient PC fax functionality ensure that your workforce has the necessary functionality needed to thrive in the modern world of business.
Samsung's unique ReCP (Rendering Engine for Clean Page) technology improves the overall quality and vibrancy of your color printing, ensuring every printout looks perfect. It automatically sharpens the focus of both graphics and text, while solid objects are overlapped to eliminate white gaps.
  • A printer that makes all smartphones smarter
  • Get print on tap
    Simply tap your mobile device to the Samsung Xpress to print virtually any content.
  • Print wirelessly share anytime
    Effortless mobile printing with professional output, optimized for any task or occasion.
  • Versatile functionalities
  • Easy to use
    Designed for simple and intuitive operation, the Samsung Multifunction Xpress C460FW saves you precious time and effort.
  • One touch eco button
    Just one push of the eco button and you can save on toner, paper, and energy. Print multiple pages on one sheet, change color to grayscale or skip blank pages.
  • One touch WPS button
    Connect quickly and securely to your wireless network with the touch of a button, via the one-touch WPS (Wi-Fi Protected Setup).
  • Direct USB printing
    Easily print images and documents directly from a USB memory stick with the intuitive menu and navigation keys.
  • Easy document creator
    Easy document creator helps you create digital documents in multiple formats and makes it easy to share them with others - via e-mail, fax or social networks.
  • Enjoy quality printouts
  • Polymerized toner
    The developed polymerized toner has smaller and more uniform particles than conventional toner. Meaning, your printouts will have crisper lines and more vivid colors - helping avoid any paper curling. Also, its higher wax content improves the image gloss and enhances the durability preventing unwanted fading.
  • Ergonomic design
    Don't worry about this printer crowding your space. Its beautiful and compact design makes it a pleasure to share a desk with.
Samsung Xpress C460FW - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
20000 impressions
Max Copying Speed
Up to 18 ppm (mono) / up to 4 ppm (colour)
Max Printing Speed
Max Printing Resolution
Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi
Scanning
600 x 600 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
40 sheets
Media Size
76 x 152.4 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, labels, recycled paper, thin paper, thick paper, glossy paper, cotton paper
Standard Media Capacity
150 sheets
Output Trays Capacity
50 sheets
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
Office Machine Features
Save to USB flash drive, scan to folder, scan to application
40.6 cm x 36.2 cm x 33.35 cm
13.98 kg
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
20000 impressions
Display
2 lines
Standard Memory
128 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
ID Card Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PostScript 3, PCL 5c, SPLC, PCL 6C
First Print Out Time B/W
14 sec
First Print Out Time Colour
26 sec
Scanning
Scan Element
CIS
Optical Resolution
600 x 600 dpi
Interpolated Resolution
4800 x 4800 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Fax Machine Features
Error Correction Mode (ECM)
Caller ID
Automatic redialing, last number redial
Document & Media Handling
Max Original Size
Original Type
Sheets
40 sheets
Min Media Size
76 x 152.4 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 76 x 152.4 mm
150 sheets
50 sheets
Paper cassette - 150 sheets size: 76 x 152.4 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 50 sheets , ADF - 40 sheets - Legal (216 x 356 mm)
Speed Details
Printing: up to 18 ppm (A4) - B/W , Printing: up to 4 ppm (A4) - colour , Printing: 19 sec (Letter A) - B/W , Printing: 4 sec (Letter A) - colour , Copying: up to 18 ppm (A4) - B/W , Copying: up to 4 ppm (A4) - colour , Copying: up to 19 ppm (Letter A) - B/W , Copying: up to 4 ppm (Letter A) - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Operating System Support
MS Windows XP, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Windows 8, Apple Mac OS X 10.5 - 10.8
290 Watt
Power Consumption Standby
60 Watt
Power Consumption Sleep
2.1 Watt
First Copy Out Time B/W
14 sec
First Copy Out Time Colour
36 sec
Consumables Included
1 x toner cartridge (black) - up to 700 pages , 1 x toner cartridge (cyan) - up to 500 pages , 1 x toner cartridge (magenta) - up to 500 pages , 1 x toner cartridge (yellow) - up to 500 pages
Limited warranty - 1 year
40.6 cm
36.2 cm
33.35 cm
13.98 kg
Sound Emission
53 dBA (operating)
