Samsung SCX-5737FW Mono Laser Wireless Multifunction Printer
Quicklinx: 7FHGWS00 Mfr#: scx-5737fw/SEE
Recent trends have shown that businesses are looking at their print environment as a way of driving efficiency throughout their business. By replacing outdated inefficient printers and copiers with energy efficient multifunction devices they can achieve productivity gains, improved device availability and significantly reduced costs. As well as helping to shrink the overall carbon footprint of an organisation, multifunction devices deliver a simple to use, yet versatile solution that is flexible enough to meet the needs of different users across the business. This enables the business to provide transparency in their costs, increased competitiveness and the ability to respond quickly to market demands. Introducing the Samsung SCX-5737FW mono laser multifunction printers. This intelligently designed range of devices offers reliable and fast performance alongside ease of use for maximum user convenience. Its high ECO credentials make it the ideal option for businesses that are looking to reduce their environmental impact as well as reduce costs, increase productivity and improve workflow.
  • No strings attached
    Turn your computer loose with wireless printing. There are no more cables tripping you up and no need to plug and unplug machines to identify the right printer. And better yet, a wireless printer can be shared by many computers, saving you money on hardware and energy costs. Break free from the restraints of cables and say goodbye to cable clutter with the SCX-5737FW wireless colour laser printer.
  • It multi-tasks so you don't have to
    Productivity is key to running any office or professional workgroup. And the versatile SCX-5737FW was designed to deliver exactly that. Now you can print, copy, scan, fax and PC-fax with unparalleled convenience, ease and speed. Why cram a corner of your office with several different machines when all you need is one central device - the SCX-5737FW laser multifunction printer.
  • Welcome to your high performance office
    The SCX-5737FW increases your productivity with a print speed of 35ppm. If its breathtakingly fast printing speed is not enough, when you factor in the processing power that comes with an 600MHz processor, fast network and memory expandable up to 768MB,, there's no doubting the high-octane performance the SCX-5637FW can bring to any office.
  • Save time and earth with convenient one-touch eco mode
    One touch of the ECO button and you've automatically selected the most eco-friendly print settings. Your printouts are automatically converted to two pages per sheet, and the toner save mode is switched on. And it doesn't stop there. With the unique Result Simulator you can see exactly how much CO2, electricity and paper you have saved with the settings you've selected. Giving you real insight into the positive impact the Samsung SCX-5737FW is having on your costs and the environment too.
  • Setup is easy withsecure, one-touch wireless connection
    The SCX-5737FW ‘s One Touch Wi-Fi Setting lets you connect quickly and easily. Simply select the WPS button on the printer , press the WPS (Wi-Fi Protected Set-up) button on the access point (router) and you're done. Normally, you would have to spend time creating a wireless network name and manually entering a security key or password on all the wireless devices. But the ultra-convenient One Touch Wi-Fi Setting automatically configures - and protects - your wireless network for you.
Samsung SCX-5737FW - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Fax Type
G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
80000 impressions
Max Copying Speed
Up to 35 ppm
Max Copying Resolution
Up to 1200 x 1200 dpi
Max Printing Speed
Up to 35 ppm
Max Printing Resolution
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Display
4.3"
Original Size
76 x 127 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper
Standard Media Capacity
300 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n)
Office Machine Features
Scan to e-mail, scan to network
46.9 cm x 43.8 cm x 44.7 cm
16.6 kg
Microsoft Certification
Compatible with Windows 7
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
80000 impressions
Display Diagonal Size
4.3"
Display Features
Touch screen
Standard Memory
256 MB 256 MB
Max Supported Memory
768 MB 768 MB
Copying
Max Copying Speed
Up to 35 ppm
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2-up, 4-up, ID Card Copy, Poster Copy, Clone Copy, collation copy
Printing
Max Printing Speed
Up to 35 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, IBM Proprinter, PDF, TIFF, XPS
Automatic Duplexing
First Print Out Time B/W
6.5 sec
Scanning
Scan Element
CIS
Interpolated Resolution
4800 x 4800 dpi
Fax Machine
Compatibility
G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 4000 pages
Fax Machine Features
Speed Dialing
200 station(s)
Broadcast Transmission
209 stations
Delayed Transmission
Fax forwarding, automatic redialing, auto reduction
Document & Media Handling
Min Original Size
76 x 127 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
Legal
Supported Media Type
300 sheets
50 sheets
150 sheets
ADF - 50 sheets , Paper cassette - 250 sheets , Bypass tray - 50 sheets , Output tray - 150 sheets
Speed Details
Printing: up to 35 ppm (A4) - B/W , Printing: up to 37 ppm (Letter A) - B/W , Copying: up to 35 ppm (A4) - B/W , Copying: up to 37 ppm (Letter A)
1 x USB 2.0 , 1 x Gigabit LAN
First Copy Out Time B/W
10 sec
Consumables Included
1 x toner cartridge
Supported Windows 7 Features
Windows HD Imaging
46.9 cm
43.8 cm
44.7 cm
16.6 kg
Shipping Width
57.5 cm
Shipping Depth
54.5 cm
Shipping Height
58.5 cm
Sound Emission
26 dBA (idle) / 54 dBA (operating)
