Enhance your notebook PC's connectivity with access to wired local area networks. A genuine Samsung Ethernet adapter dongle allows quick and easy access to LANs, giving you the connections you need for work or recreation. The Samsung AA-AE0NAMB LAN dongle is designed for use with Samsung series 9 notebook PCs and optimized so that you can get the most from all your devices. Just plug in and get connected.
