Put on the Gear VR, and you're there in the moment. Amazing display, wide field of view, precise head-tracking and low latency bring reality to the virtual. Gear VR works seamlessly with smartphones. All you need to do is slip in your phone and you're free to take on the world and beyond. To reach advanced levels, a comfortable headset is a must. And with its larger touchpad, you get easy and accurate control.
Crisp display
Put on the Gear VR, and you're there in the moment. Amazing display, wide field of view, precise head-tracking and low latency bring reality to the virtual. -
Great compatibility
Gear VR works seamlessly with smartphones. All you need to do is slip in your phone and you're free to take on the world and beyond. -
Elegant design
- Samsung Gear VR - SM-R324 - virtual reality headset for mobile phone
- Product Type
- Virtual reality headset
- Intended For
- Mobile phone
- Integrated Components
- Accelerometer, gyroscope, proximity sensor
- Wireless Interface
- Bluetooth
- Package Content
- Remote control, virtual reality headset
- 20.78 cm x 12.25 cm x 9.86 cm
- 345 g
- Orchid grey
- Designed For
- Galaxy Note5, S6, S6 edge, S6 edge+, S7, S7 edge, S8, S8+
- Product Type
- Intended For
- Mobile phone
- Bluetooth 4.2
- Package Content
- 20.78 cm
- 12.25 cm
- 9.86 cm
- 345 g
- Orchid grey
- Designed For
- Samsung Galaxy Note5, S6, S6 edge, S6 edge+, S7, S7 edge, S8, S8+
