Meta Quest 3 - 512GB - B Grade
Quicklinx: HLJPWS00 Mfr#: 400021096
Item comes with full manufacturer UK warranty. These items have been out to customers and returned, but are all in excellent condition. Any problems with the item on arrival you can return under DSR for a full refund as stock is limited. Asgard's Wrath content not included.
Meet Meta Quest 3
Breakthrough mixed reality. Jaw-dropping experiences. Get ready to explore like never before.
Expand your world with Meta Quest 3, a mixed reality headset that lets you jump into full immersion or blend physical and virtual worlds to transform your home into an exciting new playground. It’s the most powerful Quest yet, reimagined from the inside out with breakthrough technology. Extraordinary experiences come to life with lightning-fast performance and dazzling details. And with the world's best library of 500+ immersive apps, there’s something for everyone to discover.
MIXED REALITY
Transform your home into so much more
Blend virtual elements into your actual space – whether you work out alongside a virtual trainer or open a portal to a new dimension through your living room wall.
NEXT-LEVEL PERFORMANCE
The most powerful Quest yet
Play immersive games that defy expectation with lightning-fast load times and incredibly crisp details thanks to double the graphic processing power of Quest 2.
RESOLUTION
Virtual reality just got even more real
Explore lifelike games and dazzling scenery with 4K+ Infinite Display resolution, which makes visuals so real that you’ll want to reach out and touch them.
TOUCH PLUS CONTROLLERS
Experiences you can feel
Feel like you’re actually holding a bow or scrambling up skyscrapers with realistic sensations and fine-tuned precision.
MAXIMUM COMFORT
Refined and designed for you
Quest 3 features a new, slimmer, more customisable design so you find the perfect fit for your face shape, hairstyle or when you’re wearing over glasses.
GAMES AND APPS
500+ immersive experiences
Discover brand new titles across gaming, fitness, entertainment, social and more – or revisit games you already love with backwards compatibility.
What’s in the box:
Meta Quest 3 Headset
Adjustable standard facial interface
Two Meta Quest Touch Plus controllers
Two wrist straps
Power adaptor
Charging cable
Meta Quest is for ages 10+
  • Blend the virtual and physical with breakthrough mixed reality
    Bring virtual elements into your physical space with natural interactions. High-fidelity, full color passthrough keeps your surroundings in sight, while stereoscopic depth perception allows you to interact with characters or objects in the room around you.
  • Surround yourself in 3D sound
    With enhanced sound clarity and an audio range that's 40% louder than the previous model, all your favorite apps become more immersive. Stream movies by creating the ultimate home theater within your headset, or play games backed by a soundtrack of booming bass that brings you straight into the action.
  • Dazzling graphics
    Delve deeper with lifelike experiences - thanks to 4K+ Infinite Display resolution. You can also see more with an increased field of view (104° horizontal / 96° vertical) that extends your peripheral vision within virtual worlds.
  • Faster load times, crisper details, smoother play
    An extremely powerful chip enables faster load times and crisper details - whether you are courtside at an NBA game or battling bad guys to save the universe.
  • Redesigned to help you find the perfect fit
    Discover the setup that works best for you, including options that let you wear your headset over glasses - or accommodate different hairstyles and face shapes.
  • Pancake lens
    Redesigned lenses and a slim profile let you stay immersed in maximum comfort with extraordinary resolution.
  • Touch Plus controllers for experiences you can feel
    Feel like you're actually swinging a saber or casting a fishing line with TruTouch haptics that let you react to every experience as if you're physically there.
Meta Quest 3 (512 GB) - virtual reality system - with Asgard's Wrath 2
Virtual reality system
Sensors
2 RGB cameras, 4 IR cameras
Resolution per Eye
2064 x 2208
Field of View
110°
Input Connectors
USB-C
1-year warranty
Bundled with
Asgard's Wrath 2
Display Type
Configuration
Qualcom Snapdragon XR2 Gen 2, 8 GB RAM
512 GB storage
Bundled with
Asgard's Wrath 2
VR Headset
Resolution per Eye
2064 x 2208
Field of View
110°
Sensors
Adjustable headband, full-colour mixed reality, 3D spatial audio
Audio
Speakers - stereo
Headphones (mini-jack) , USB-C
Haptic feedback, pancake lens, lens adjustment
2 x AA batteries, power adapter, 2 wrist straps, 2 Touch Plus controllers
Charging cable
Dimensions & Weight Details
Headset - weight: 515 g
Limited warranty - 1 year
HLJP Meta Quest 2 Link Cable In Stock £70.83
