Meet the earbuds designed to tune in to every moment—with an iconic shape and ergonomic design, a fit that lets in your natural surroundings and a speaker optimized for a better experience. This is sound made for your ears.
The newest shape of true wireless earbuds
Galaxy Buds Live's eye-catching design stands out, even inside your ear. Reflecting the natural curves of the ear and face, they're set off with a glossy finish. It all comes together with a jewelry box-inspired case that fits in your hand when on the go. -
Made for your ears
Fit for all-day comfort with less fatigue, Galaxy Buds Live sit softly inside the ear. Its ergonomic design is snug yet non-intrusive with two wing tip sizes for a better fit. Run an errand, run your day or just go for a run all without your buds slipping out your ears. -
Hear every sound come alive
Experience sound like you're in the front row. 12mm speakers with sound by AKG compliment Galaxy Buds Live's ergonomic design to deliver spacious sound. The large driver and bass duct help emit deep bass with air flow that lets sound flow seamlessly. -
Lasts for hours
Get long-lasting battery life when you're on the go with a case that doubles as a wireless charger. One full charge provides a workday's worth of play time. The case holds up to an additional two charges. -
Power for even more playtime
Charge for just a few minutes so you can get back into the groove. Five minutes gets you an hour, whether you want to listen to your favorite playlist or the latest podcast. If you need a little bit extra, you can even use your smartphone to wirelessly give Galaxy Buds Live a charge on the go. -
Words go through crisp and clear
With three built-in mics and a Voice Pickup Unit, you get the best call quality from true wireless earbuds. The Voice Pickup Unit senses when your jaw is moving, and as your jaw vibrates this data is converted into voice signals that enhanced your sound quality - even in a noisy place. -
Touch and hold, then Spotify plays
Galaxy Buds Live's Spotify integration lets you assign a shortcut on your phone. Touch and hold for one second to instantly access all your favorite playlists. Half a million podcasts and 50 million songs are all at your fingertips. -
A smart assistant who listens back
Bixby voice wake-up is ready whenever you call. It wakes up to your voice, letting you control your phone without lifting a finger. Manage your calls, adjust the volume or check the weather while on the move. You talk, Bixby listens. -
Share and listen with a friend
Share music without sharing your earbuds. With Buds Together, simply connect both yours and a friend's Galaxy Buds Live to your phone and listen to your favorite throwbacks together. The music goes on and on, for you both.
- Samsung Galaxy Buds Live - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Recommended Use
- Portable electronics
- Mystic white
- Headphones Form Factor
- In-ear
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Active Noise Canceling
- Microphones Included
- 3
- Intelligent Assistant
- Bixby
- 1-year warranty
- Product Type
- True wireless earphones - Bluetooth - wireless
- Dimensions & Weight Details
- Earbud: 1.65 cm x 1.49 cm x 2.73 cm / 5.6 g , Charging case: 5 cm x 2.78 cm x 5.02 cm / 42.2 g
- 1.65 cm
- 1.49 cm
- 2.73 cm
- 5.6 g
- Mystic white
- Recommended Use
Audio Output
- In-ear
- Connectivity Technology
- Wireless
- Bluetooth
- Bluetooth Audio Codec
- SBC, AAC, Samsung Scalable
- Bluetooth Version
- Bluetooth 5.0
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Active Noise Cancelling Technology
- Acoustic Noise Cancelling
- Diaphragm
- 12 mm
Microphone
- Form Factor
- Built-in
- 3
Tracking
- Sensors
- Accelerometer, gyro sensor, hall sensor, grip sensor, infrared (IR) sensor, touch sensor, Voice Pickup Unit (VPU)
- Connector Type
- Bluetooth , USB (power only) (24 pin USB-C)
Internet of Things (IoT)
- Bixby
- Included Accessories
- 2 pairs of ear tips (small, large), charging case (472 mAh)
- Cable Details
- USB-C charge cable - detachable
- IPX2
- Battery
- Headphone battery rechargeable - wireless charging
- Wireless Charging Standards
- Qi
- Capacity
- 60 mAh
- Run Time (Up To)
- 6 hour(s)
- Run Time Details
- Continuous playback: up to 6 hours , Continuous talk: up to 4.5 hours , Continuous playback (with included charging case): up to 21 hours , Continuous playback (ANC and Bixby Voice Wake-up OFF): up to 8 hours , Continuous playback (ANC and Bixby Voice Wake-up OFF / with included charging case): up to 29 hours
- Standby Time
- 21 hours
- Limited warranty - 1 year
