A processor that means business
Stay on top of your to-do list with the latest 13th Gen Intel® Core™ processor. It delivers superior multi-core performance, powering through workloads at incredible speeds.
Your work on full display
Get lost in crisp 3K (2880x1800) resolution and super-smooth 120Hz as they deliver a cinematic and seamless viewing experience. Every detail comes to life on the 14 or 16-inch screen. Stay in the zone for as long as you like thanks to reduced blue light emission for extra eye care.
More touch pad. More possibility
With an expanded touch pad and wide range of built-in ports, get the plugs and versatility you've been searching for — HDMI, USB-A, microSD slot and even two Thunderbolt 4 ports for blazing-fast 40 Gbps file transfers. No dongle needed
Battery that lasts through overtime
Power through the day's projects with a long-lasting 76Wh (typical) battery for up to 19 hours of video runtime. Then grab a coffee as you top up your laptop with up to 6.7 hours of video runtime in just 30 minutes — with a compact charger that even works with your other Samsung Galaxy devices.
Break time sounds good
From project kickoff to match kickoff, catch everything with the depth and clarity of the quad-speaker system on Galaxy Book3 Pro. The four immersive speakers are tuned with AKG and Dolby Atmos, so every victory sounds better than ever.
Career-accelerating speed
This processor means business. Achieve it all with the powerful processor. Plus, this on-the-go powerhouse seamlessly syncs with other Galaxy devices to multiply multitasking with ease. -
See your ambitions come to life on a 3K AMOLED screen. This jaw-dropping laptop continues Samsung's rich heritage of innovative displays with a 16:10 aspect ratio, the largest ever for Galaxy. -
Thin, light, premium design
Pursue your ambitions from anywhere with an amazingly thin, lightweight design. This powerful PC is ready to move with you on your trip to the top. -
Packed with ports
Look like a pro while you're owning the day with a wide range of ports - plus a larger touchpad. No need for a clunky adapter. Connect to bigger screens, external storage devices and more with ease. -
Power to move forward
Get your hustle on all day long with a powerful battery that keeps you on the move for hours and hours. -
Command the room from anywhere
Whether you're live streaming or video conferencing, make an impact with a Full HD webcam, studio-quality dual mics and four AKG-tuned speakers to help you hear every word. -
From conference calls to streaming shows, hear every comment with depth and clarity. Four immersive speakers are tuned with AKG and Dolby Atmos for a superb audio experience. -
Advanced security
Work confidently from any location with aadvanced Galaxy Book security. Plus, a fingerprint reader gives you secure and easy access to your laptop while keeping out unwanted users. -
The Galaxy connected experience
Multiply your productivity with one seamless experience across all your devices. Galaxy breaks down barriers so you can do more effortlessly.
- Samsung Galaxy Book3 Pro - 16" - Intel Core i7 - 1360P - Evo - 16 GB RAM - 512 GB SSD
- Product Type
- Notebook
- Operating System
- Win 11 Home
- Platform Technology
- Intel Evo
- Processor
- Intel Core i7 (13th Gen) - 1360P / 2.2 GHz, up to 5 GHz / 18 MB Cache
- Memory
- 16 GB LPDDR5 (provided memory is soldered)
- Storage
- 512 GB SSD - NVMe
- Display
- 16" 2880 x 1800 / WQXGA+ @ 120 Hz - 212 ppi
- Graphics
- Intel Iris Xe Graphics
- Input Device
- ClickPad
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 5.1, 802.11a/b/g/n/ac/ax (Wi-Fi 6E)
- Ambient light sensor
- Security
- Trusted Platform Module (TPM) Security Chip, fingerprint reader
- Graphite
- 35.54 cm x 25.04 cm x 1.25 cm
- 1.56 kg
- Specific Absorption Rate (SAR)
- 0.607 W/kg (body) , 0.607 W/kg (limb)
- Limited warranty - 2 years
- Product Type
- Notebook
- Operating System
- Windows 11 Home
Processor / Chipset
- CPU
- Intel Core i7 (13th Gen) 1360P / 2.2 GHz
- Max Turbo Speed
- 5 GHz
- Number of Cores
- 12-core
- Cache
- L3 - 18 MB
- Intel Evo
- RAM
- 16 GB (provided memory is soldered)
- Technology
- LPDDR5 SDRAM
- Speed
- 6000 MHz
Storage
- Main Storage
- 512 GB SSD M.2 PCIe 4.0 - NVM Express (NVMe)
Display
- 16" - AMOLED
- Resolution
- 2880 x 1800 (WQXGA+)
- V-Sync Rate at Max Res.
- 120 Hz
- Widescreen
- Pixel Density (ppi)
- 212
- Image Aspect Ratio
- 16:10
- Image Brightness
- 500 cd/m²
- Colour Support
- 16 million colours
- Colour Gamut
- 120% DCI-P3
- HDR 500 True Black, 0.2 ms response rate, Eye Caring, gaming performance
- Keyboard Name
- Pro keyboard
Audio & Video
- Graphics Processor
- Video System Features
- Functions as Intel UHD graphics (for single-channel memory)
- Camera
- Yes - 1080p
- Sound
- AKG stereo speakers, dual array microphone
- Dolby Atmos
- Audio Features
- Output: Smart Amp
Input
- Keyboard, ClickPad
- Numeric Keypad
- Backlit
Communications
- Wireless
- Dual stream (2x2)
- Technology
- Lithium Ion
- Capacity
- 76 Watt
AC Adapter
- Output
- 65 Watt
Connections & Expansion
- Slots
- 2 x SSD (1 free)
- Interfaces Details
- HDMI , USB 3.2 , Headphone/microphone combo jack , 2 x USB-C (supports Thunderbolt 4)
- Memory Card Reader
- Yes (microSD)
Software
- Software Included
- Live Wallpaper, Screen Recorder, Samsung Gallery, Quick Search, Samsung Flow, Samsung Notes, Samsung Recovery Solution, Samsung Settings, Studio Plus, Samsung Update, Samsung Pass, Second Screen, Quick Share, Private Share, Galaxy Book Smart Switch, Galaxy Book Experience
- Graphite
- Integrated Options
- Security
- Included Accessories
- 65W USB-C power adapter
- IEC 61960
- 1.56 kg
