Dynamic AMOLED 2X. All your ideas on display
Showcase your brilliant concepts on the equally brilliant 14 or 16-inch display. Your content looks spectacular in high resolution with bright and vivid colors, smooth scrolling and onscreen motion, and reduced blue light emission for eye comfort.
New touchscreen. Productivity at your fingertips
Touch and feel the responsive screen of Galaxy Book4 Pro. Now, the Dynamic AMOLED 2X touch-enabled display allows you to easily navigate through apps and content with the tip of your finger.
Power up with next-level AI performance
Get things done — super-fast and super-smooth. The next-gen Intel® Core™ Ultra processor is equipped with an advanced NPU to deliver transformative AI-powered performance. Multitask seamlessly with pro-level apps and complete demanding projects with ease.
Anti-reflective cover glass. Dazzling views at any angle
Get a clear view of what you love with Corning® Gorilla® Glass with DX. This anti-reflective cover glass on the display reduces distracting reflections and glare, helping onscreen content to be sharp and readable at varying viewing angles and particularly in brightly lit conditions.
It's all clear with Vision Booster
Vision Booster automatically detects the amount of sunlight and adjusts the contrast and colour of the screen, improving visibility in various weather conditions.
Fast charging. All-day productivity
Whether you're hard at work or unwinding with games, Galaxy Book4 Pro 16" model's battery will last throughout the day, supporting up to 21 hours of video runtime. And if you're low on battery, not to worry — use Fast Charging to charge up to 35% in just about 30 minutes with the compact charger.
Stunning visuals
Experience clarity and color accuracy with the Samsung Galaxy Book4 Pro's OLED display, featuring a native resolution of 2880 x 1800, 120% DCI-P3 color gamut, and anti-glare technology for breathtaking visuals in any lighting condition. -
Powerful performance
Equipped with a 16-core Intel Core Ultra 7 processor with a max turbo speed of 4.8 GHz and 512 GB NVMe SSD, the Samsung Galaxy Book4 Pro delivers swift and efficient performance for all your computing needs. -
Immersive audio experience
Dive into a world of sound with Dolby Atmos compliant AKG quad speakers and dual array microphone, ensuring crystal-clear audio whether you're enjoying media or in a conference call. -
Seamless connectivity
Stay connected with the most recent in wireless and port technology, including Wi-Fi 6E, Bluetooth 5.3, Thunderbolt 4, and multiple USB interfaces, providing fast and versatile connection options for all your devices. -
Enhanced security and convenience
The Samsung Galaxy Book4 Pro features an embedded Trusted Platform Module (TPM) security chip and a fingerprint reader, offering both enhanced security and the convenience of easy logins.
- Samsung Galaxy Book4 Pro - 16" - Intel Core Ultra 7 - 155H - Evo - 16 GB RAM - 512 GB SSD
- Product Type
- Notebook
- Operating System
- Win 11 Home
- Platform Technology
- Intel Evo
- Processor
- Intel Core Ultra 7 (Series 1) - 155H / 1.4 GHz, up to 4.8 GHz / 24 MB Cache
- Neural Processor Unit (NPU)
- Intel AI Boost
- Memory
- 16 GB LPDDR5X SDRAM (provided memory is soldered)
- Storage
- 512 GB SSD - NVMe
- Display
- 16" touchscreen 2880 x 1800 / WQXGA+ @ 120 Hz
- Graphics
- Intel Arc Graphics
- Input Device
- ClickPad
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3
- Ambient light sensor
- Security
- Trusted Platform Module (TPM) Security Chip, fingerprint reader
- Moonstone grey
- 35.54 cm x 25.04 cm x 1.25 cm
- 1.56 kg
- Limited warranty - 1 year
- Product Type
- Notebook
- Operating System
- Windows 11 Home
Processor / Chipset
- CPU
- Intel Core Ultra 7 (Series 1) 155H / 1.4 GHz
- Max Turbo Speed
- 4.8 GHz
- Number of Cores
- 16-core
- Cache
- L3 - 24 MB
- Intel Evo
- Intel Smart Cache
- Intel AI Boost
- Sparsity Support
- AI Software Frameworks Supported by NPU
- DirectML, OpenVINO, WindowsML, ONNX RT
- Windows Studio Effects Support
- RAM
- 16 GB (provided memory is soldered)
- Technology
- LPDDR5X SDRAM
Storage
- Main Storage
- 512 GB SSD PCIe - NVM Express (NVMe)
Display
- 16" - AMOLED
- Touchscreen
- Resolution
- 2880 x 1800 (WQXGA+)
- V-Sync Rate at Max Res.
- 120 Hz
- Widescreen
- Image Aspect Ratio
- 16:10
- Image Brightness
- 400 cd/m²
- Colour Gamut
- 120% DCI-P3
- Anti-glare, blue light reduction, 0.2 ms response rate, cinematic experience, gaming performance, GorillaGlass with DX
- Keyboard Name
- Pro keyboard
Audio & Video
- Graphics Processor
- Camera
- Yes - 1080p
- Resolution
- 2 Megapixel
- Camera Features
- Wide angle lens, auto framing, Eye Contact function
- Sound
- AKG quad speakers, dual array microphone
- Dolby Atmos
- Audio Features
- Output: Smart Amplification technology
Input
- Keyboard, ClickPad
- Numeric Keypad
Communications
- Wireless
- Dual stream (2x2)
- Capacity
- 76 Wh
- Battery Run Time
- Video playback: up to 21 hours
AC Adapter
- Output
- 65 watt
Connections & Expansion
- Interfaces Details
- HDMI , 2 x Thunderbolt 4 , USB 3.2 , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
Software
- Software Included
- Samsung Recovery Solution, Samsung Update, Samsung Settings, Samsung Gallery, Studio Plus, Samsung Flow, Live Wallpaper, Quick Search, Samsung Notes, Screen Recorder, Galaxy Book Smart Switch, Quick Share, Samsung Pass, Second Screen, Private Share, Galaxy Book Experience
- Moonstone grey
- Integrated Options
- Security
- Vision Booster
- Included Accessories
- 65W USB-C power adapter
- Cables Included
- USB-C to USB-C cable
- IEC 61960, SGS Eye Care Display Certification, Carbon Trust
- 1.56 kg
Sustainability Information
- Product Recycled Content
- Recycled materials
- Packaging Recycled Content
- 100 % - recycled paper
