Samsung Galaxy 2 PRO360 I71260 16G/512G W11P
Quicklinx: GT5CWS00 Mfr#: NP930QED-KA8UK
  • Core i7
  • IEEE 802.11n
Turn your work/life balance completely around with Samsung Galaxy Book Pro 360. Precisely write down notes with Samsungs redesigned S Pen, immerse yourself in the 120% color volume on a Super AMOLED touchscreen and feel the power of the latest Intel Core processor. And with 5G connectivity, you can work and watch your favorite content anywhere. The new way to PC. Galaxy Book.
  • Speeds that move as fast as you do
    Get the speeds you need to blaze through your work in record time, then binge-watch a show or game with virtually zero lag.
  • Get 360 degrees of thin
    Turn heads with a stylish, 2-in-1 device that's as powerful as a PC and as thin as a smartphone. Designed to switch between PC and tablet, Galaxy Book Pro 360 is made to make you look good.
  • The power to create it, the storage to keep it
    Do all the things you need to do with plenty of storage and less lag.
  • Work and play with the rest of your Galaxy
    Pair your devices and easily jump from your work life to your personal life on your Galaxy Book Pro 360. Set it up as a second screen for twice the productivity, or use it for beautiful note-taking with Samsungs improved S Pen. Plus, you can instantly share files with Quick Share and play mobile games on a larger display. And with your Galaxy Buds Pro, you can smoothly switch from video conferences to catching up with friends.
  • Look like a pro, even in your living room
    Make WFH work for you with tools that help you look, sound and do your best. Attend a last-minute meeting and still make a good impression with the camera's beauty filter.
  • See how the Galaxy Book Pro 360 stacks up
    Explore how this Galaxy Book stacks up to others in processor speed, battery power, display quality and more.
Samsung Galaxy Book2 Pro 360 - 13.3" - Intel Core i7 - 1260P - Evo - 16 GB RAM - 512 GB SSD
Notebook - flip design
Operating System
Win 11 Pro
Platform Technology
Intel Evo
Intel Core i7 (12th Gen) - 1260P / 2.1 GHz, up to 4.7 GHz / 18 MB Cache
16 GB LPDDR5 (provided memory is soldered)
Storage
512 GB SSD - NVMe
Display
13.3" touchscreen 1920 x 1080 / Full HD
Graphics
Intel Iris Xe Graphics
Input Device
ClickPad, S Pen
Integrated Webcam
Bluetooth 5.1, 802.11a/b/g/n/ac/ax
Accelerometer, ambient light sensor, gyro sensor
Security
Trusted Platform Module (TPM) Security Chip, fingerprint reader
Graphite
30.25 cm x 20.2 cm x 1.15 cm
1.04 kg
Limited warranty - 1 year
Operating System
Windows 11 Pro
Processor / Chipset
CPU
Intel Core i7 (12th Gen) 1260P / 2.1 GHz
Max Turbo Speed
4.7 GHz
Number of Cores
12-core
Cache
L3 - 18 MB
Platform Technology
Intel Evo
Intel Deep Learning Boost (DL Boost)
RAM
16 GB (provided memory is soldered)
LPDDR5 SDRAM
Storage
Main Storage
512 GB SSD - NVM Express (NVMe)
Display
13.3" - AMOLED
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Keyboard Name
Pro keyboard
Audio & Video
Graphics Processor
Camera
Yes - 1080p
Camera Features
Auto framing
Sound
AKG stereo speakers, dual array microphone
Dolby Atmos
Audio Features
Output: Smart Amp
Input
Keyboard, ClickPad, S Pen
Communications
Wireless
Dual stream (2x2)
63 Wh
AC Adapter
Output
65 watt
Connections & Expansion
Interfaces Details
Thunderbolt 4 , 2 x USB-C , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Software
Software Included
Live Message, Live Wallpaper, McAfee LiveSafe (Trial), Screen Recorder, Samsung Gallery, Samsung Flow, Samsung Recovery Solution, Samsung Settings, Samsung Notes, Samsung Update, Studio Plus, Samsung Security, Quick Search, Galaxy Book Smart Switch
Graphite
Integrated Options
Security
USB-C power adapter
IEC 61960
1.04 kg
