Samsung Book 3 Pro 360 5G
Quicklinx: HTTSWS00 Mfr#: NP965QFG-KA1UK
  • Core i5
  • IEEE 802.11n
Immerse yourself in true, crisp 3K (2880x1800) resolution that lets you see everything in bold color and sharp detail — even if your office is outdoors; Plus enjoy 120 Hz smoothness as you type, tap and draw
Step up your game and speed up your work with blazing-fast speeds and smooth performance; Your workloads and games are no match for the latest 13th Gen Intel Core processor
With an expanded touch pad and wide range of built-in ports, get the plugs and versatility you've been searching for — HDMI, USB-A, microSD slot and even two Thunderbolt 4 ports for blazing-fast 40 Gbps file transfers No dongle needed
Get your popcorn ready — the quad-speaker system on Galaxy Book3 Pro 360 features four immersive speakers, AKG and Dolby Atmos technology to ensure a crystal-clear experience from opening scene to post-credits
Studio Mode gets you camera-ready with smart features — from enhanced AI Noise Cancelling, to Auto Framing and background effects Combined with the wide-angle camera and studio-quality mics, it ensures you look and sound your best on every video call
  • Touchable, versatile, wonderful
    Sketch out your next venture, your five-year plan or the design that changes everything with S Pen. It's all possible on an innovative 2-in-1 display - the screen folds back on a 360-degree hinge for amazing flexibility.
  • A screen like you've never seen
    Create on the ultimate canvas - a stunning 3K AMOLED touchscreen (2880 X 1800) with 16:10 aspect ratio, the largest ever for Galaxy. Whether you're making sketches or spreadsheets, the 2-in-1 display flips 360-degrees to go from laptop to tablet in a snap.
  • Power your passions
    Go-getters and visionaries, empower your imagination with the 13th Gen Intel Core processor. Blazing-fast speeds and smooth performance help your creative mind thrive.
  • Packed with ports
    Connect easily with a wide range of ports. HDMI, USB-A, Micro SD slot and two Thunderbolt 4 ports keep your creative flow going without a clunky adaptor. Plus, a larger touchpad.
  • Power to move forward
    Power through big projects with a long-lasting battery. Charge up in a flash with a Fast-Charging USB-C charger that works with all your Galaxy devices.
  • Command the room from anywhere
    Whether you're live streaming or video conferencing, make an impact with a full-HD webcam, studio-grade mics and four AKG-tuned speakers to help you hear every word.
  • The Galaxy connected experience
    Multiply your productivity with one seamless experience across all your devices. Galaxy breaks down barriers so you can do more effortlessly.
Samsung Galaxy Book3 Pro 360 - 16" - Intel Core i5 - 1340P - Evo - 8 GB RAM - 256 GB SSD - 5G
Notebook - 2-in-1 - flip design
Operating System
Win 11 Home
Platform Technology
Intel Evo
Intel Core i5 (13th Gen) - 1340P / 1.9 GHz, up to 4.6 GHz / 12 MB Cache
8 GB LPDDR5 (provided memory is soldered)
Storage
256 GB SSD - NVMe
Display
16" touchscreen 2880 x 1800 / WQXGA+ @ 120 Hz - 212 ppi
Graphics
Intel Iris Xe Graphics
Input Device
ClickPad, S Pen
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.1
Wireless Broadband (WWAN)
5G
Service Provider
Not specified
Up to 19 hours
Ambient light sensor, accelerometer, gyro sensor
Security
Trusted Platform Module (TPM) Security Chip, fingerprint reader
Graphite
35.54 cm x 25.22 cm x 1.28 cm
1.71 kg
Notebook - Yes - flip design
Operating System
Windows 11 Home
Processor / Chipset
CPU
Intel Core i5 (13th Gen) 1340P / 1.9 GHz
Max Turbo Speed
4.6 GHz
Number of Cores
12-core
Cache
L3 - 12 MB
Platform Technology
Intel Evo
Intel Smart Cache, Intel Thread Director, Intel Adaptix Technology, Intel Speed Shift Technology, Hyper-Threading Technology, Intel Deep Learning Boost (DL Boost)
RAM
8 GB (provided memory is soldered)
LPDDR5 SDRAM
Storage
Main Storage
256 GB SSD - NVM Express (NVMe)
Display
16" - AMOLED
Touchscreen
Resolution
2880 x 1800 (WQXGA+)
V-Sync Rate at Max Res.
120 Hz
Widescreen
Pixel Density (ppi)
212
Image Aspect Ratio
16:10
Image Brightness
500 cd/m²
Colour Support
16 million colours
Colour Gamut
120% DCI-P3
Eye Caring, HDR 500 True Black, 0.2 ms response rate, cinematic experience, gaming performance
Keyboard Name
Pro keyboard
Audio & Video
Graphics Processor
Video System Features
Functions as Intel UHD graphics (for single-channel memory)
Camera
Yes - 1080p
Sound
AKG quad speakers, dual array microphone
Dolby Atmos
Audio Features
Output: Smart Amp
Input
Keyboard, ClickPad, S Pen
Keyboard Backlight
Numeric Keypad
Communications
Wireless
Dual stream (2x2)
Generation
5G
5G Sub-6 Ghz
Service Provider
Not specified
Navigation
Receiver
GPS/GLONASS/Galileo/BeiDou
Lithium Ion
76 watt
Run Time
Up to 19 hours
Battery Run Time
Video playback: up to 19 hours
AC Adapter
Output
65 watt
Connections & Expansion
Interfaces Details
HDMI , USB 3.2 (Type A) , Headphone/microphone combo jack , 2 x USB-C (supports Thunderbolt 4) (Power Delivery)
Memory Card Reader
Yes (microSD)
Software
Software Included
Live Wallpaper, Screen Recorder, Samsung Gallery, Quick Search, Samsung Flow, Samsung Notes, Samsung Recovery Solution, Samsung Settings, Studio Plus, Samsung Update, Samsung Pass, Second Screen, Quick Share, Private Share, Galaxy Book Experience, Galaxy Book Smart Switch
Graphite
Integrated Options
Security
65W USB-C power adapter
1.71 kg
