Samsung AKG VL3 Wireless Smart Speaker - White
Quicklinx: FGRFWS00 Mfr#: VL351/XU
Experience studio-quality sound in your own space. Listen to crisp hi-fi sound, fine-tuned and certified by AKG.
  • Let the original sound come alive
    Experience a new level of clarity with new Ultra High Quality (UHQ) Audio technology, which upscales both existing 8 to 24-bit audio to output at 32-bit, so your favorite songs sound closer to the original recording.
  • Feel the deep bass
    The Distortion Canceling technology predicts and cancels out distortion before it happens, giving you deep and detailed bass without the need for a separate subwoofer.
  • Moving Dial Control goes where you go
    Just rotate and click. Or use your voice. With the Moving Dial Control, you can adjust the volume, skip songs, and use voice commands to get what you need - anywhere in your space. It's so easy to enjoy great sound.
  • Sync with your mobile
    Just long-press and talk to the moving dial. Using Bluetooth, it syncs with your mobile and finds the music you want.
Samsung VL351 - smart speaker
Smart speaker
Speaker Type
2-way - active
Ethernet, Bluetooth, Wi-Fi
Platform
SmartThings
Intelligent Assistant
Alexa - indirect
Audio Formats
WAV, AAC, AIFF, MP3, FLAC, OGG, ALAC
White
21 cm x 7 cm x 21.15 cm
2.1 kg
Smart speaker
Enclosure Colour
White
Design Features
Tuned by AKG
Speaker System
Speaker Type
2-way - active
High-Resolution Audio
Multiroom
Amplifier
Integrated
IEEE 802.3 (Ethernet), Bluetooth, Wi-Fi
Audio Formats
Controls
Volume, play/pause
Internet of Things (IoT)
Platform
SmartThings
Communications Type
Product-to-product
Alexa
Voice Control
Indirect
Speaker System Details
Driver Details
Woofer driver , Tweeter driver
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , LAN (RJ-45)
AC power adaptor, remote control with microphone
Power Source
AC power adapter
21 cm
7 cm
21.15 cm
2.1 kg
