Product
Samsung 960 PRO 1TB NVMe PCIe V-NAND M.2 SSD
Clearance!
Clearance
Limited Time Offer
Quicklinx: CGH5WS00 Mfr#: MZ-V6P1T0BW
Select:
  • 1TB
Experience incredible performance, designed for heavy workloads and demanding applications with the high-capacity, highly reliable Samsung 960 PRO hard drive. Ideal for advanced PCs and workstations, the 960 PRO boasts an amazing 48-layer Samsung V-NAND-based architecture, that delivers excellent performance in a compact M.2 form factor.
  • Experience excellent performance
    The NVMe interface of the 960 PRO supports PCIe lanes for an enhanced bandwidth and lower latency. You can experience massive sequential R/W (read/write) speeds.
  • Amazing performance and capacity
    Samsung provides advanced end-to-end integration for the hard drives. The 960 PRO is optimized for performance and capacity, enabling you to store a lot of data on a single NVMe hard drive.
Samsung 960 PRO MZ-V6P1T0BW - solid state drive - 1 TB - PCI Express 3.0 x4 (NVMe)
Solid state drive - internal
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Multi-level cell (MLC)
M.2 2280
TRIM support, sleep mode, Auto Garbage Collection Algorithm, TurboWrite Technology, V-NAND Technology, eDrive, NVM Express (NVMe), S.M.A.R.T., 256-bit AES, IEEE 1667
22.1 mm x 80 mm x 2.28 mm
9 g
1 TB
Hardware Encryption
256-bit AES
M.2 2280
22.1 mm
80 mm
2.28 mm
9 g
Performance
SSD Endurance
800 TB
Internal Data Rate
3500 MBps (read) / 2100 MBps (write)
Maximum 4KB Random Write
440000 IOPS
Maximum 4KB Random Read
360000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe) - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
1.2 Watt (idle) , 5.3 Watt (average) , 5 mW (sleep)
Software Included
Samsung Magician Software
70 °C
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
