Samsung 960 EVO 500GB V-NAND M.2 SSD
Quicklinx: CJBDWS00 Mfr#: MZ-V6E500BW
Discover the advancement in SSD technology with this high-performance, highly reliable 960 EVO Series NVMe M.2 SSDs. Non-Volatile Memory Express (NVMe) with a Polaris controller outperforms the SATA SSDs with exceptionally fast read/write speeds, and Samsung TurboWrite technology accelerates write speeds even further.
  • Raise your performance expectations
    Enhanced bandwidth beyond the SATA interface provided by the NVMe interface, combined with the Polaris controller facilitates sequential read/write speeds up to 3,200 MB/s and 1,800 MB/s respectively. Plus, the intelligent TurboWrite technology accelerates write speeds even further.
  • Rest easy with solid reliability
    Dynamic Thermal Guard prevents overheating, protecting your data and ensuring optimal performance.
Samsung 960 EVO MZ-V6E500BW - SSD - 500 GB - PCIe 3.0 x4 (NVMe)
Solid state drive - internal
500 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Triple-level cell (TLC)
M.2 2280
PCIe 3.0 x4 (NVMe)
TRIM support, sleep mode, Auto Garbage Collection Algorithm, TurboWrite Technology, V-NAND Technology, eDrive, NVM Express (NVMe), S.M.A.R.T., 256-bit AES, IEEE 1667
22.1 mm x 80 mm x 2.28 mm
9 g
3-year warranty
500 GB
Hardware Encryption
256-bit AES
M.2 2280
PCIe 3.0 x4 (NVMe)
22.1 mm
80 mm
2.28 mm
9 g
Performance
SSD Endurance
200 TB
Internal Data Rate
3200 MBps (read) / 1800 MBps (write)
Maximum 4KB Random Write
330000 IOPS
Maximum 4KB Random Read
330000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe) - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
1.2 watt (idle) , 5.4 watt (average) , 5 mW (sleep)
Software Included
Samsung Magician Software
Limited warranty - 3 years
70 °C
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
