Samsung 860 DCT 960GB SATA 2.5" SSD Hard Drive
Quicklinx: DWZBWS00 Mfr#: MZ-76E960E
Samsung's 860 DCT SSDs deliver optimized performance and value for read-intensive applications like servers and data centers.
  • Optimized performance
    Built to handle the heavier workloads of data center usage, the 860 DCT delivers a high level of sustained performance at a great value for your business.
  • Outstanding reliability
    The 860 DCT is optimized for server and data center environments by offering reinforced endurance, and low power consumption.
Samsung 860 DCT MZ-76E960E - SSD - 960 GB - SATA 6Gb/s
Solid state drive - internal
960 GB
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
TRIM support, Auto Garbage Collection Algorithm, V-NAND Technology, Samsung MJX Controller, S.M.A.R.T., 256-bit AES
69.85 mm x 100 mm x 6.8 mm
51 g
3-year warranty
960 GB
256-bit AES
2.5"
SATA 6Gb/s
69.85 mm
100 mm
6.8 mm
51 g
Performance
SSD Endurance
349 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 520 MBps (write)
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
2.9 Watt (average) , 1.05 Watt (idle max)
WWN
Limited warranty - 3 years
70 °C
