Samsung 850 EVO 2TB Basic SATA 6Gb/s 2.5" Solid State Drive
Quicklinx: BHNHWS00 Mfr#: MZ-75E2T0B/EU
Upgrade virtually every aspect of your computer's performance with Samsung's 850 EVO, designed with state-of-the-art SSD advancements including 3D V-NAND technology.
  • 3D V-NAND technology
    Samsung's 3D V-NAND flash memory architecture breaks through density limitations, performance and endurance of today's conventional planar NAND architecture. Samsung 3D V-NAND stacks 32 cell layers vertically resulting in higher density and better performance utilizing a smaller footprint.
  • Optimize daily computing with TurboWrite technology for unrivaled read/write speeds
    Achieve the ultimate read/write performance to maximize your everyday computing experience with Samsung's TurboWrite technology.
Samsung 850 EVO Basic MZ-75E2T0 - solid state drive - 2 TB - SATA 6Gb/s
Solid state drive - internal
2 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
2 GB
Hardware Full Disk Encryption (FDE), TRIM support, DevSleep mode, Microsoft eDrive compatible, 3D V-NAND Technology, Auto Garbage Collection Algorithm, Dynamic Thermal Guard protection, Worldwide Name (WWN), RAPID mode support, TurboWrite Technology, Samsung MHX Controller, Low Power DDR3 SDRAM Cache, S.M.A.R.T., 256-bit AES, IEEE 1667
69.85 mm x 100 mm x 6.8 mm
66 g
5-year warranty
2 TB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
Buffer Size
2 GB
69.85 mm
100 mm
6.8 mm
66 g
Performance
SSD Endurance
150 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 520 MBps (write)
4KB Random Read
98000 IOPS
Maximum 4KB Random Write
90000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
4.7 Watt (average) , 2 mW (sleep) , 7.2 Watt (maximum) , 60 mW (idle)
Software Included
Samsung Magician Software
Limited warranty - 5 years
70 °C
5 - 95% (non-condensing)
Shock Tolerance (non-operating)
1500 g @ 0.5 ms half-sine pulse
