Brand
Samsung 512GB 970 Pro V-NAND M.2 NVMe Phoenix Controller SSD
Quicklinx: DJS4WS00 Mfr#: MZ-V7P512BW
Form Factor: M.2 2280
Capacity: 512GB
Interface: PCI Express 3.0 x4 (NVMe)
Type: Internal hard drive
Select:
£156.10 ex VAT
£187.32 inc VAT
THE SAMSUNG SSD 970 PRO
The Samsung SSD 970 PRO is the 3rd generation of Samsung’s Client-PC NVMe SSD. The Samsung 970 PRO is specially designed for tech enthusiasts, hardcore gamers and professionals whose workloads are intensive on PCs and workstations. Featuring the latest Samsung 2bit MLC V-NAND technology and a newly enhanced Phoenix controller, the 970 PRO delivers fearless performance and unprecedented reliability in a small M.2 2280 form factor and offer customers the most advanced Samsung SSD technology currently available for Client PCs.
Fearless Performance
Delivering unprecedented performance, the 970 PRO maximizes the potential of NVMe bandwidth. With much greater performance than the previous generation, the new 970 PRO offers unparalleled sequential read/write speeds of up to 3,500/2,700 MB/s respectively and random performance of up to 500,000 IOPS for both of read/write operations. The 970 PRO is the best solution for processing massive amounts of data, 4K graphic work, 4K/DirectX 12 games and data analytics.
Unparalleled Reliability & Exceptional Endurance
The 970 PRO boasts exceptional endurance with up to 1,200 TBW, which is 50 percent higher than that of the previous model, thanks to the latest Samsung V-NAND technology.* Thermal control solutions enable enhanced performance with reduced heat risk. Dynamic Thermal Guard(DTG) technology proactively prevents overheating, and a heat spreader with an integrated thin copper film dissipates heat more efficiently. A new nickel coating on the Phoenix controller also helps to shed heat faster during heavy workload use in order to ensure the high levels of quality and reliability for which Samsung is known. The 970 PRO comes with a 5-year warranty. *All documented endurance test results are obtained in compliance with JESD218 standards. Please visit www.jedec.org for detailed information on the standard.
System Design Flexibility
The 970 PRO enables convenient storage expansion across many different devices. The 970 PRO comes in 512GB/1TB capacities in a compact M.2 2280 form factor. In addition, the 970 PRO offers high power efficiency as well as exceptional speed, making it the ideal solution to use with applications ranging from ultra-thin computing to high-performance computing systems.
Advanced Data Encryption
The 970 PRO provides multiple advanced data encryption features. Self-Encrypting Drive (SED) security technology will help keep data safe at all times. The 970 PRO includes an AES 256-bit hardware-based encryption engine to ensure that your personal files remain secure. Being hardware-based, the encryption engine secures your data without the performance degradation that you may experience with software-based encryption. Also, the 970 PRO is compliant with various advanced security management solutions (TCG Opal and Encrypted Drive-IEEE1667).
Samsung Data Migration and Magician Software
The 970 PRO comes with Samsung Data Migration and Magician software, which is easy to install and makes management of you SSD simple.* Samsung Data Migration software is easy to use, yet provides a very powerful "Custom Cloning" feature that makes migration effortless even when the amount of source data is greater than the SSD’s capacity. Magician provides personalized firmware checks and additional functionality tailored to the drives of individual users. It even updates the firmware automatically to make sure that the drive’s performance stays up to date.
*To download Samsung Data Migration and Magician, please visit www.samsung.com/samsungssd
Samsung 970 PRO MZ-V7P512BW - SSD - 512 GB - PCIe 3.0 x4 (NVMe)
Solid state drive - internal
512 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
3D multi-level cell (MLC)
M.2 2280
PCIe 3.0 x4 (NVMe)
Microsoft eDrive compatible, Auto Garbage Collection Algorithm, V-NAND Technology, Temperature Monitoring, NVM Express (NVMe) 1.3, Samsung Phoenix Controller
22.15 mm x 80.15 mm x 2.38 mm
7.93 g
5-year warranty
512 GB
Hardware Encryption
256-bit AES
M.2 2280
PCIe 3.0 x4 (NVMe)
22.15 mm
80.15 mm
2.38 mm
7.93 g
Performance
SSD Endurance
600 TB
Internal Data Rate
3500 MBps (read) / 2300 MBps (write)
Maximum 4KB Random Write
500000 IOPS
Maximum 4KB Random Read
370000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
PCI Express 3.0 x4 (NVMe) - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
8.5 Watt (active configurable max) , 5.2 Watt (active) , 30 mW (idle max)
IEEE 1667
Limited warranty - 5 years
70 °C
Shock Tolerance (operating)
1500 g @ 0.5 ms half-sine
Capacity: 512GB
Brand: Samsung
