X52 PRO FLIGHT SYSTEM
The most fully integrated Stick and throttle flight controller: built to meet the demands of the best virtual pilots in the world!
The MFD screen, first introduced on the X52 Flight Controller, is now interactive. Now you can display important in-game information such as the Radio Stack and interact with your games directly. Shipping with support for Microsoft's Flight Simulator X, there's also a Software Development Kit (SDK) included which allows budding programmers to create interactions with their own favourite games. See what's been created already on our forum.
New metal parts increase durability and the unique dual-spring mechanism provides a progressive spring force on the stick's movement, making it more resistant the further you move it from centre. The X52 Pro uses the same magnetic hall sensor, non-contact technology as the X52 but we've doubled the number of sensors to improve response. The smooth movement and enhanced control give you unparalleled accuracy and bring you even closer to reality.
Joystick
- Precision centering mechanism, non-contact technology on X and Y axes and constant spring force reduce free play, improve control and increase durability
- 2-stage metal trigger; 2 primary buttons in 1 convenient position
- 4 fire buttons including missile launcher with spring-loaded safety cover for instant access
- Conveniently positioned metal pinkie switch provides shift functionality to double up on programmable commands
- 2 X 8-way Hat Switches
- 3D rudder twist
- 3-position rotary mode selector switch with LED indicators
- 3 spring-loaded, base-mounted toggle switches for up to 6 programmable flight commands
- 5-position handle adjustment system to suit all hand sizes
Throttle
- Progressive throttle with tension adjustment, detents for afterburner and idle
- 2 fire buttons
- Scroll wheel with built-in button
- Mouse controller / hat switch with left mouse button
- 8-way hat switch
- 2 x rotary controls
- Smooth-action slider control
- Clutch button initiates `safe mode' to allow on-the-fly profile selection, or to display button functionality without activating
- Saitek X52 Pro Flight Control System - joystick and throttle - wired
- Product Type
- Joystick and throttle
- Connectivity Technology
- Wired
- Pointing Device / Manipulator
- Joystick, throttle, three 8-way hat switches
- 8-way hat switch, mouse control, adjustable tension, rotary control, scrolling wheel, backlighting, illuminated buttons, multi-function display
- Microsoft Certification
- Works with Windows Vista
- Product Type
- Wired
- Interface
- USB
- 1 x USB - 4 pin USB Type A
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Customer reviews
Write a review for the Saitek X52 Pro Flight Control System here!
Saitek X52 Pro With rudder pedals
Reviewed by Kris. Review Posted 25/01/2009
What a great joystick. This is a must have for any Flight sim fan The joystick is very easy to use and sey up. And the pedals are a good addition.
A++++++++
Overall
Ease of use
Value for money
Incredible
Reviewed by . Review Posted 23/11/2008
Bought this joystick 5 months ago and it has been wonderful.
It works extremely well with FSX and the SST is very useful.
overall a great bit of kit.
Overall
Ease of use
Value for money
Awesome
Reviewed by . Review Posted 05/01/2008
This piece is absolutely awesome! Wouldn't change for anything cheaper.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
