Saitek Pro Flight Yoke System
Customer rating: 4.0* (Write a review)
Quicklinx: 4QZ6WS00 Mfr#: PZ44
The Saitek Pro Flight Yoke System is highly engineered to meet the exacting needs of the true flight simulation enthusiast. Stainless steel shaft, ergonomic controls, integrated chronograph and separate throttle quadrant ensure a smooth, accurate and totally realistic flying experience.
Use the integrated USB Hub to easily connect other parts of the Saitek Pro Flight range of products, such as additional Pro Flight Throttle Quadrant or Pro Flight Instrument Panel (both sold separately)
Connectivity: USB 2.0
Works with: Windows XP, XP64 and Vista (all versions)
Saitek Pro Flight Yoke System - yoke - wired
Yoke
Wired
Buttons Qty
14
Controls
3-way switch
Microsoft Certification
Works with Windows Vista
PC
Yoke
Wired
Buttons Qty
14
Controls
3-way switch
USB
1 x USB - 4 pin USB Type A
Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Vista
Software Included
Saitek Smart Technology (SST)
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
PC
Customer reviews
Write a review for the Saitek Pro Flight Yoke System here!
What you get!
Reviewed by Anonymous Review Posted 21/10/2008
Just to clarify the question from the other review "what do I get?" - I asked the same question and got no reply! - I took a chance and ordered it anyway!.
The answer is "YES" you get the steering yoke and the flight quadrant as well! - Nice bit of kit and will review it better after I get it out of the box and try!.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Reviewed by Anup Das. Review Posted 20/02/2008
I got my Saitek Pro Flight Yoke system in Feb 2008. No squeaksand nor does any button pushes on their own -Saitek may have fixed this problem. I am delighted with my Yoke system and it works well with MS Flightsimulator X. It gives a realistic feel of a joystick - just like the real thing. Installation has not been a problem - I just followed the instructions. However, if you want to customise settings (highly recommended) then you will need to know what you're doing. You can,of course, always go back to default settings which works just as well.
  • Overall 5*
  • Ease of use 5*
Reviewed by Anup_K_Das@hotmail.com. Review Posted 20/02/2008
I got my Saitek Pro Flight Yoke system in Feb 2008. No squeaks nor does any button pushes on their own -Saitek may have fixed this problem. I am delighted with my Yoke system and it works well with MS Flight Simulator X. It gives a realistic feel of a joystick - just like the real thing. Installation has not been a problem - I just followed the instructions. However, if you want to customise settings (highly recommended) then you will need to know what you're doing. You can,of course, always go back to default settings which works just as well.
  • Overall 5*
  • Ease of use 5*
Read all 5 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
