Sahara Wall Mounted Active Whiteboard Speakers
Quicklinx: 4QRDWS00 Mfr#: 1050006
The Sahara Wall Mounted Active Whiteboard Speakers is a wall mounted active and passive speaker set suitable for mounting either side of an interactive whiteboard in a classroom environment.
Sahara Wall Mounted Active Whiteboard - speakers
Speakers
System Components
2 speakers
Speaker Type
2-way - active
Nominal Output Power (Total)
32 Watt
Frequency Response
20 - 20000 Hz
Amplifier
Integrated
Speaker System Details
2 16 Watt - 20 - 20000 Hz
Grey
13.5 cm x 9.8 cm x 61 cm
Speakers
Enclosure Colour
Grey
Grille Colour
Speaker System
System Components
2 speakers
Speaker Type
2-way - active
Audio System Continuous Power (Total)
32 Watt
Frequency Response
20 - 20000 Hz
Signal-To-Noise Ratio
80 dB
Total Harmonic Distortion
0.2%
Max Output Level (Max SPL)
75 dBA
Amplifier
Integrated
Recommended Placing
Wall-mountable
Controls
Power on/off, volume
Interface Type
USB
Speakers Included
2 - 2-way - 16 Watt - 20 - 20000 Hz - wall-mountable - wired
Driver Details
2 x woofer driver - 4" , Tweeter driver - 1"
Connector Type
2 x audio line-in (mini-phone stereo 3.5 mm) , 3 x USB (4 PIN USB Type A) , USB (4 PIN USB Type B)
Speaker cable, 2 audio cables
Power supply - internal
Power Source
USB
13.5 cm
9.8 cm
61 cm
