Enterprises can easily and affordably build high-speed Ruckus ZoneFlex 802.11n wireless networks that deliver wire-like reliability and consistent performance at range, which drives the need for fully-managed, rack-mountable, Layer 2, 24-port 10/100/1000 Mbps Ethernet POE switch. The ZoneSwitch 4000 series is a cost effective solution ideal for enterprise deployment at the edge of the network. Completely interoperable with Ruckus ZoneFlex APs, the ZoneSwitch 4124 supports 24 concurrent IEEE 802.3af connections.
- Ruckus ZoneSwitch 4124 - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 (PoE) + 4 x shared SFP
- Power Over Ethernet (PoE)
- PoE
- Capacity
- Virtual interfaces (VLANs): 256
- Jumbo Frame Support
- Routing Protocol
- IGMPv2, IGMP
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH-2, CLI
- Flow control, Layer 2 switching, auto-sensing per device, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, traffic shaping, port mirroring, DiffServ support, Broadcast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), IP Precedence, Jumbo Frames support, LLDP support, Link Aggregation Control Protocol (LACP), Dynamic VLAN Support (GVRP)
- IEEE 802.3, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 25.7 cm x 4.4 cm
- 4.38 kg
- Localisation
- United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- Capacity
- Routing Protocol
- IGMPv2, IGMP
- Encryption Algorithm
- SSL
- Authentication Method
- RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- Status Indicators
- Power, status
- 24 x 1000Base-T RJ-45 PoE , 1 x console DB-9 management , 4 x SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- Localisation
- United Kingdom
- 44 cm
- 25.7 cm
- 4.4 cm
- 4.38 kg
- Limited warranty - lifetime
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 10 - 95% (non-condensing)
