With 1080HD video, two-way audio and customizable motion sensors, the new Video Doorbell Pro is most advanced doorbell yet.
Get instant alerts when visitors press your doorbell or trigger the built-in motion sensors, and see, hear and speak to anyone at your door from your smartphone, tablet or PC.
With an ultra-slim design and customizable faceplates, Ring Pro has a finish to match your home and your style.
Putting the pro in protection
Video Doorbell Pro 2 is Ring's best-in-class doorbell for ultimate performance and protection. See and hear like never before with boosted HD+ video and crisp audio quality. Pinpoint movement with 3D Motion Detection. And with Alexa Greetings, Alexa can speak to visitors and accept deliveries when you can't get to the door. It's the first doorbell to run your front door. -
Get the whole picture
See more of who stops by and check in on package deliveries down low with Head-to-Toe HD+ Video in 1536p. You'll also never miss a thing, even in the dark or bad weather, with crystal-clear color night vision. -
The best motion detection on the block
Pinpoint motion and distance with 3D Motion Detection - the first feature of its kind, only available on Video Doorbell Pro 2.
- Ring Video Doorbell Pro 2 - doorbell - 802.11a/b/g/n/ac - satin nickel - with plug-in adapter
- Product Type
- Doorbell
- Functions
- Motion detection, camera
- Power Source
- Power adapter
- Intelligent Assistant
- Alexa
- Bundled with
- Plug-in adapter
- Connectivity
- Wireless - 802.11a/b/g/n/ac
- Frequency Band
- 2.4 Ghz, 5 GHz
- Supported Host Device OS
- Android, iOS, Windows, MacOS
- Camera
- Audio - Day&Night
- Satin nickel
- 1-year warranty
- 4.9 cm x 2.2 cm x 11.4 cm
- Product Type
- Doorbell
- Functions
- Power Source
- Power adapter
- Bundled with
- Plug-in adapter
- Connectivity Technology
- Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11a
- Frequency Band
- 2.4 Ghz, 5 GHz
- Weatherproof, instant alerts
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Communications Technology
- Wi-Fi
- Alexa
Camera
- Day & Night Functionality
- Audio Support
- Video Modes
- 1556p
- 3D Motion Detection, 2-way voice communication, Live View Control, noise-cancellation, Bird's Eye View, Colour Night Vision, people only mode, advanced pre-roll, customisable motion zones, 150° field of view (horizontal), 150° field of view (vertical), Head to Toe Video
Software
- Ring Protect (30 days trial)
- Included Accessories
- Faceplate (satin nickel), installation kit, corner kit, security sticker
- Satin nickel
- Warranty
- 1-year warranty
- 12 Watt
- 4.9 cm
- 2.2 cm
- 11.4 cm
- -20.5 °C
- 48.5 °C
