Ring Stick-Up Cam Battery - White
Quicklinx: GGN8WS00 Mfr#: B099M24J56
Add security anywhere – inside or out – with the versatile Stick Up Cam Battery. Its wire-free design means you can put it where you need it and move it when you need to. Place it on a flat surface for flexibility or mount it to a wall for a more permanent solution. With Stick Up Cam Battery, you’ll always be connected to home so you can see what’s happening at anytime.
Ring Stick Up Cam Battery - network surveillance camera
Network surveillance camera - fixed - indoor, outdoor - weatherproof
Audio
Yes: two-way audio capability, built-in speaker, built-in microphone
Camera Mount Type
Wall mount, surface mount
5.99 cm x 5.99 cm x 9.7 cm
154 g
White
Wireless
Camera
Colour - Day&Night
Motion Detection
Video Modes
1080p
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Intelligent Assistant
Alexa
1 - micro-USB charge cable - external
Smartphone Monitoring
1-year warranty
Environmental Parameters (operating)
-20 °C - 50 °C
Audio Support
Camera Mount Type
Wireless
5.99 cm
5.99 cm
9.7 cm
154 g
Camera
Colour - Day&Night - fixed - indoor, outdoor - weatherproof
Motion Detection
Video Modes
1080p
Digital Video Capture Resolution
1920 x 1080
Lens Construction
Horizontal Field of View (degree)
110
Vertical Field of View (degree)
57
Diagonal Field of View (degree)
130
Network Interface
Rechargeable battery, mounting kit, security sticker
1 x micro-USB charge cable - external
White
1
Internet of Things (IoT)
Alexa
Limited warranty - 1 year
-20 °C
50 °C
