Ring Spotlight Cam Wired - Black
Quicklinx: D4CSWS00 Mfr#: 8SH2P7-BEU0
Spotlight Cam Wired
HD camera with two-way talk and spotlights, plugged-in for non-stop power and security.
Home Security in Your Hands
Protect and monitor your home with Spotlight Cam Wired, a plugged-in HD security camera that lets you see, hear and speak to anyone on your property from your phone, tablet and PC.
• Brilliant 1080HD video
• Wide-angle camera lens
• Built-in microphone and speakers
Never Miss a Thing
Create and customize your own motion zones, so you can focus on the most important areas of your yard. When motion is detected, you’ll get an instant alert to let you know someone’s at your home.
• Advanced motion detection
• Custom motion zones and scheduling
• Instant motion-activated alerts
Stop Crime Before It Happens
With built-in spotlights and night vision, you’ll get crisp video 24/7, with or without the lights on. And if you catch a suspicious stranger at your home, use the 110-decibel alarm to scare them away.
• Spotlights are motion-activated or controlled with the app
• Infrared night vision sensors
• 110-decibel siren alarm
Non-Stop Power and Security
Spotlight Cam Wired plugs into standard power outlets to give you non-stop power, so you’ll never need to charge a battery. It also comes with everything you need to get your Cam setup in just minutes.
• Plug-and-play installation
• Live View on-demand video and audio
• iOS, Android, Mac and Windows 10 compatible
Ring Protect Plans
Real-time Ring alerts, Real-time motion alerts, Custom motion detection, Two-way talk, Live View and Theft Protection are included as standard with all Ring products. All Ring products come with a 2 year warranty.
If you want to store, review, share and download videos from your events you will need to purchase a Ring Protect Plan, available from £2.50 per month. These are available from https://en-uk.ring.com/pages/protect-plans.
  • Never miss a thing
    Create and customize your own motion zones, so you can focus on the important areas of your yard. When motion is detected, you'll get an instant alert to let you know someone's at your home.
  • Stop crime, before it happens
    With built-in spotlights and night vision, you'll get crisp video 24/7, with or without the lights on. And if you catch a suspicious stranger at your home, use the loud alarm to scare them away.
  • Nonstop power and security
    Spotlight Cam Wired plugs into standard power outlets to give you nonstop power, so you'll never need to charge a battery. It also offers everything you need to get your Cam set up.
Ring Spotlight Cam Wired - network surveillance camera
Network surveillance camera - fixed - outdoor - weatherproof
Audio
Yes: built-in speaker, built-in microphone
6.91 cm x 7.59 cm x 12.6 cm
Wireless
Camera
Colour - Day&Night
Video Modes
1080p
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Motion sensor, built-in siren
2 year warranty
Environmental Parameters (operating)
-28 °C - 48 °C
Audio Support
Wireless
6.91 cm
7.59 cm
12.6 cm
Camera
Colour - Day&Night - fixed - outdoor - weatherproof
Video Modes
1080p
Infrared LEDs
Lens Construction
Horizontal Field of View (degree)
140
Network Interface
Power adapter
Limited warranty - parts - 2 year
-28 °C
48 °C
