Take your siren outside. Enhance your Alarm Security System and let the neighbourhood know you have whole-home security covered. If there's an emergency, Outdoor Siren can help others quickly identify your home with an adjustable volume siren and flashing LED lights. Connect an additional compatible power source and turn on the Dusk to Dawn feature to use Alarm Outdoor Siren as an everyday security sign.
Dusk to Dawn. With the Dusk to Dawn feature, you can activate the logo light on a schedule in the Ring app. With Dusk to Dawn activated, your Outdoor Siren will be visible after dark and will let the neighbourhood know you have security covered.
To use the Dusk to Dawn feature you will need to power Outdoor Siren with a Quick Release Battery Pack combined with a Solar Panel for a continuous charge, or hardwired for non-stop power. Outdoor Siren also supports Ring Plug-in Adapter (2nd Generation) which allows you to power the Dusk to Dawn feature from an internal electrical socket.
Enhance your Ring Alarm Security System and let the neighborhood know you have whole-home security covered. If there's an emergency, Outdoor Siren can help others quickly identify your home with an adjustable volume siren and flashing LED lights. Connect an additional compatible power source and turn on the Dusk to Dawn feature to use Ring Alarm Outdoor Siren as an everyday security sign. -
Dusk to Dawn
With the Dusk to Dawn feature, you can activate the logo light on a schedule in the Ring app. With Dusk to Dawn activated, your Outdoor Siren will be visible after dark and will let the neighborhood know you have security covered. To use the Dusk to Dawn feature you will need to power Outdoor Siren with a Quick Release Battery Pack combined with a Solar Panel for a continuous charge, or hardwired for non-stop power. Outdoor Siren also supports Ring Plug-in Adapter (2nd Generation) which allows you to power the Dusk to Dawn feature from an internal electrical socket.
- Ring Outdoor Siren - siren - Z-Wave - blue
- Product Type
- Siren
- Environment
- Outdoor
- Power Source
- Battery, hardwired
- Connectivity
- Wireless - Z-Wave
- Siren Sound Level
- 100 dB
- Adjustments
- Volume
- Blue
- 1-year warranty
- 23.5 cm x 5.7 cm x 23.5 cm
- Product Type
- Siren
- Environment
- Outdoor
- Power Source
- Connectivity Technology
- Wireless - Z-Wave
- Max Range Open Space
- 76 m
- Siren Sound Level
- 100 dB
- Adjustments
- Volume
- Visual alert, Dusk to Dawn feature, wall mountable, weather-resistant
- Form Factor
- D type
- Battery Included
- Required Qty
- 3
- Battery Lifetime
- 3 years
- Blue
- Warranty
- 1-year warranty
- 23.5 cm
- 5.7 cm
- 23.5 cm
- -20 °C
- 49 °C
