Brand
Ring Alarm Outdoor Siren
Quicklinx: GBQ1WS00 Mfr#: 4AS1S1-0EU0
Type: Siren
Compatible With: Alexa
£52.68 ex VAT
£63.21 inc VAT
Take your siren outside. Enhance your Alarm Security System and let the neighbourhood know you have whole-home security covered. If there's an emergency, Outdoor Siren can help others quickly identify your home with an adjustable volume siren and flashing LED lights. Connect an additional compatible power source and turn on the Dusk to Dawn feature to use Alarm Outdoor Siren as an everyday security sign.
Dusk to Dawn. With the Dusk to Dawn feature, you can activate the logo light on a schedule in the Ring app. With Dusk to Dawn activated, your Outdoor Siren will be visible after dark and will let the neighbourhood know you have security covered.
To use the Dusk to Dawn feature you will need to power Outdoor Siren with a Quick Release Battery Pack combined with a Solar Panel for a continuous charge, or hardwired for non-stop power. Outdoor Siren also supports Ring Plug-in Adapter (2nd Generation) which allows you to power the Dusk to Dawn feature from an internal electrical socket.
  • Take your siren outside
    Enhance your Ring Alarm Security System and let the neighborhood know you have whole-home security covered. If there's an emergency, Outdoor Siren can help others quickly identify your home with an adjustable volume siren and flashing LED lights. Connect an additional compatible power source and turn on the Dusk to Dawn feature to use Ring Alarm Outdoor Siren as an everyday security sign.
  • Dusk to Dawn
    With the Dusk to Dawn feature, you can activate the logo light on a schedule in the Ring app. With Dusk to Dawn activated, your Outdoor Siren will be visible after dark and will let the neighborhood know you have security covered. To use the Dusk to Dawn feature you will need to power Outdoor Siren with a Quick Release Battery Pack combined with a Solar Panel for a continuous charge, or hardwired for non-stop power. Outdoor Siren also supports Ring Plug-in Adapter (2nd Generation) which allows you to power the Dusk to Dawn feature from an internal electrical socket.
Ring Outdoor Siren - siren - Z-Wave - blue
Siren
Environment
Outdoor
Power Source
Hardwired, battery
Wireless - Z-Wave
Siren Sound Level
100 dB
Adjustments
Volume
Blue
1-year warranty
23.5 cm x 5.7 cm x 23.5 cm
Siren
Environment
Outdoor
Power Source
Hardwired, battery
Wireless - Z-Wave
Max Range Open Space
76 m
Siren Sound Level
100 dB
Adjustments
Volume
Wall mountable, visual alert, weather-resistant, Dusk to Dawn feature
D type
Battery Included
Required Qty
3
Battery Lifetime
3 years
Blue
Warranty
1-year warranty
23.5 cm
5.7 cm
23.5 cm
-20 °C
49 °C
Type: Siren
Brand: Ring
