When armed, the Ring Alarm Security Kit sends notifications to your phone and tablet whenever doors or windows open and when motion is detected at home. It's fully customizable and expands to fit any house or apartment. And the free Ring App puts your entire home security system at your fingertips. It also has a Panic Mode feature, which allows you to dispatch emergency services right from your Keypad.
Enhanced connectivity
With both wired and wireless connectivity options, including Ethernet, Wi-Fi, and Z-Wave, this home security system offers flexible installation and easy integration into your existing smart home setup. -
Comprehensive security
The Alarm Security Kit comes equipped with a base station, extender, keypad, and motion sensor, ensuring your home is monitored from every angle. The 104 dB siren sound level provides a loud alert in case of security breaches, making it an effective deterrent against potential intruders. -
Reliable power options
Powered by both a battery and a power adapter, and featuring a 24-hour backup battery, this system ensures your home remains secure even in the event of a power outage.
- Ring Alarm Security Kit - 1st Generation - 5-piece set - home security system - ZigBee, Wi-Fi, Z-Wave - white
- Product Type
- Home security system
- Power Source
- Battery, power adapter
- Intelligent Assistant
- Alexa
- Package Content
- Door and window sensor, motion sensor, keypad, base station, extender
- Connectivity
- Wireless, wired - ZigBee, Wi-Fi, Z-Wave - Ethernet
- Siren Sound Level
- 104 dB
- Input Type
- Keypad
- White
- 1-year warranty
- Product Type
- Power Source
- Package Content
- Connectivity Technology
- Wireless, wired - Ethernet, Z-Wave, ZigBee, Wi-Fi
- Max Range Indoors
- 76.2 m
- Siren Sound Level
- 104 dB
- OS Required
- Android, Apple iOS
- 24 hours backup battery, panic function Bluetooth management
Control Unit
- Input Type
- Keypad
- Built-in Devices
- Battery
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Alexa
- Battery Included
- White
- Nominal Voltage
- AC 120/230 V
- Warranty
- 1-year warranty
- Dimensions & Weight Details
- Base station: 16.9 cm x 3.61 cm x 16.9 cm , Keypad: 10.5 cm x 1.91 cm x 11.2 cm , Door and window sensor: 3.96 cm x 1.4 cm x 5.31 cm , Motion sensor: 6.6 cm x 3.89 cm x 6.6 cm , Extender: 4.72 cm x 4.22 cm x 8.1 cm
- 0 °C
- 40 °C
