The advanced SP C440DN has a sophisticated feature set providing best-in-class total cost of ownership for an A4 mid-range color printer. An output speed of 40ppm combined with an impressive array of security functions, flexible media options and eco-friendly operation make the SP C440DN the ideal solution for your color print needs. And an ECOnomy color output mode significantly reduces the cost compared to full color printing.
A 40ppm output speed allows you to benefit from improved efficiency for print jobs. Using the optional XPS Direct Print Option you can even print straight from a PC or USB device without a driver for complete flexibility. A maximum 2300 sheet paper capacity means the SP C440DN can easily meet all your output needs, producing labels and flyers in color.
- Ricoh SP C440DN - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 57 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Max Media Size (Custom)
- 216 mm
- Print Speed
- Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 40 ppm - colour - A4 (210 x 297 mm) , Up to 40 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 40 ppm - colour duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, USB 2.0 host
- Processor
- RM7035 533 MHz
- RAM Installed (Max)
- 1 GB (1 GB)
- Card Reader
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PDF
- Media Type
- Envelopes, plain paper, recycled paper, lettering tape, thick paper, thin paper, label paper, preprinted paper, coated paper, glossy paper
- Total Media Capacity
- 650 sheets
- Media Handling
- 550-sheet input tray, 100-sheet bypass tray
- Monthly Duty Cycle (max)
- 150000 pages
- Networking
- Print server
- System Requirements
- HP-UX 11.x, IBM AIX 5L, HP-UX 11i v2, SCO OpenServer 5.0.7, Microsoft Windows Server 2003, SunSoft Solaris 2.9, IBM AIX 5.3, Red Hat Enterprise Linux 4, SCO OpenServer 6, SunSoft Solaris 2.10, Microsoft Windows Server 2008 R2, HP-UX 11i v3, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, Red Hat Enterprise Linux 6, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / 7 / 8 / 8.1, Apple MacOS X 10.7 - 10.10
- 44.4 cm x 65.8 cm x 49 cm
- Printer Type
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- Direct Printing Specifications
- PictBridge
- PostScript Support
- Standard
- First Print Out Time B/W
- 10 sec
- First Print Out Time Colour
- 15 sec
- Fonts Included
- 58 x PCL , 136 x PostScript 3
- Media Handling
- Processor
- RM7035 533 MHz
RAM
- 1 GB / 1 GB (max)
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 216 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm), Foolscap (216 x 343 mm)
- Media Weight
- 52 g/m² - 256 g/m²
- 650 sheets
- Media Feeders
- 1 x automatic - 550 sheets - Legal (216 x 356 mm) weight: 52 g/m² - 220 g/m² , 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 52 g/m² - 256 g/m²
- Max Media Capacity
- 2300 sheets
Duty Cycle
- 150000 pages
- Networking
- Print server
- LDAP, 802.1x
- Connections
- 1 x USB 2.0 host - 4 pin USB Type A , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner refill (black) - up to 3000 pages ISO/IEC 19798 , 1 x toner refill (yellow) - up to 3000 pages ISO/IEC 19798 , 1 x toner refill (magenta) - up to 3000 pages ISO/IEC 19798 , 1 x toner refill (cyan) - up to 3000 pages ISO/IEC 19798
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 771 Watt
- Power Consumption Stand by
- 157 Watt
- Power Consumption Sleep
- 0.66 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- 44.4 cm
- 65.8 cm
- 49 cm
- 57 kg
